1 - 1 of
11
1 - 1 of
11
Hello Linn - there are different ways to support the joint. Ultimately, it will represent some kind of spring-damper situation.
a) you may add a torsion spring at that joint location between the 2 bodies
b) you may add a bushing and provide stiffness and damping in the direction about which the joint rotates.
c) you can add a force with an expression that represents a spring damper.
The spring damper is the simplest. If you do not care about the rotating degree of freedom of the joint, you may even add a motion with 0.0 displacement on the joint.
Regards
Praful
Regards
Praful
