High Energy Error
Hello,
for my Formula Student Team I am trying to simulate the deformation of the Anti Intrusion Plate. To replicate the real test I've tried to implement the Honeycomb Impact Attenuator Tutorial(https://altairuniversity.com/wp-content/uploads/2016/11/Crash_Box_1.pdf). I've attached the file. When I try to run the simulation the Energy Errror starts at 0% and then rockets up to 99.9%. Then the Simulation stops.
ROOT: SteelDummy RESTART: 0001
NUMBER OF HMPP PROCESSES 4
02/12/2019
NC= 0 T= 0.0000E+00 DT= 2.1400E-04 ERR= 0.0% DM/M= 1.7748E-05
ANIMATION FILE: SteelDummyA001 WRITTEN
NC= 100 T= 2.1400E-02 DT= 2.1400E-04 ERR= -0.0% DM/M= 1.7748E-05
ELAPSED TIME= 54.23 s REMAINING TIME= 126646.67 s
NC= 200 T= 3.5753E-02 DT= 1.2229E-04 ERR= -0.0% DM/M= 1.7748E-05
ELAPSED TIME= 54.82 s REMAINING TIME= 76607.94 s
NC= 300 T= 4.7072E-02 DT= 1.0479E-04 ERR= -0.0% DM/M= 1.7748E-05
ELAPSED TIME= 55.35 s REMAINING TIME= 58738.95 s
NC= 400 T= 5.6878E-02 DT= 9.1867E-05 ERR= -0.0% DM/M= 1.7748E-05
ELAPSED TIME= 55.87 s REMAINING TIME= 49054.49 s
MESSAGE ID : 259
** WARNING ZERO OR NEGATIVE VOLUME : 3D-ELEMENT ID : 700
ELEMENT IS SWITCHED TO SMALL STRAIN OPTION
MESSAGE ID : 259
** WARNING ZERO OR NEGATIVE VOLUME : 3D-ELEMENT ID : 1940
MESSAGE ID : 259
** WARNING ZERO OR NEGATIVE VOLUME : 3D-ELEMENT ID : 3120
MESSAGE ID : 259
** WARNING ZERO OR NEGATIVE VOLUME : 3D-ELEMENT ID : 4080
NC= 500 T= 6.2841E-02 DT= 1.1098E-13 ERR= 99.9% DM/M= 1.7748E-05
ELAPSED TIME= 56.40 s REMAINING TIME= 44815.82 s
NC= 600 T= 6.2841E-02 DT= 1.1098E-13 ERR= 99.9% DM/M= 1.7748E-05
ELAPSED TIME= 56.93 s REMAINING TIME= 45237.79 s
NC= 700 T= 6.2841E-02 DT= 1.1098E-13 ERR= 99.9% DM/M= 1.7748E-05
ELAPSED TIME= 57.43 s REMAINING TIME= 45635.91 s
NC= 800 T= 6.2841E-02 DT= 1.1098E-13 ERR= 99.9% DM/M= 1.7748E-05
ELAPSED TIME= 57.99 s REMAINING TIME= 46084.90 s
NC= 900 T= 6.2841E-02 DT= 1.1099E-13 ERR= 99.9% DM/M= 1.7748E-05
ELAPSED TIME= 58.58 s REMAINING TIME= 46552.16 s
MESSAGE ID : 205
** RUN KILLED : ENERGY ERROR LIMIT REACHED
NC= 1000 T= 6.2841E-02 DT= 5.1022E-18 ERR= 99.9% DM/M= 1.7748E-05
ELAPSED TIME= 59.22 s REMAINING TIME= 47060.74 s
ANIMATION FILE: SteelDummyA002 WRITTEN
Thanks upfront,
Konrad
