1 - 1 of
11
1 - 1 of
11
Hi Kiran,
Can you add the EDEM lib and bin paths to your System environment variables:
https://help.altair.com/EDEM/Adding_EDEM_to_the_Filepath.htm
Note the link shows the path for the 2022.1 version but you should use the version and location of EDEM that you are using on your PC.
Regards
Stephen
Hi Kiran,
Regards
Stephen
