I have tried coupling CFD-DEM using EDEM and Ansys. When i read the journal file. I see the following error.
I followed the coupling procedure and the command prompt said the coupling was successful.
Please help.
Thanks,Kiran
Hi Kiran,
Can you add the EDEM lib and bin paths to your System environment variables:
https://help.altair.com/EDEM/Adding_EDEM_to_the_Filepath.htm
Note the link shows the path for the 2022.1 version but you should use the version and location of EDEM that you are using on your PC.
Regards
Stephen
