🎉Community Raffle - Win $25
Join and Win
Snap Fit analysis
User: "Harsh2610"
Altair Community Member
Updated by Harsh2610
Hello '
I am doing snap fit analysis for a bottle and cap. I have an error.
ERROR ID :          183
** ERROR IN HIERARCHY (PART TO SUBSET ID)
DESCRIPTION :
   -- PART ID : 1
   -- PART TITLE : Bottle
   REFERS TO UNEXISTING SUBSET ID=2
I refer previous queries regarding same issue. so i check /PART in component. Still issue continues.
1 - 7 of 71
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi,
    Please try with the attached file.
    The issue was related with the surface segment created.
    User: "Harsh2610"
    OP
    Hello George,
    Thank You.
    Still There is another issue. I run the analysis. But run time is high and there is no animation files created.
    Altair Employee
    Hi,
    Try running with the engine file attached.
    The model seems like there is no node selected for the imposed displacement load collector. Please recheck/review the loads defined in the model.
    User: "Harsh2610"
    OP
    Hii george,
    Thank you.... It works
    what are the changes u have done in engine file?
    Altair Employee
    Hi,
    I just used a higher time step value for the run in the modified engine file.
    Before imposing a time step value always check the current time step in the starter out (_0000.out) file and accordingly assign a time step value and also ensure that the mass added is also within the limit.
    User: "Harsh2610"
    OP
    Hi,
    how to check current time step
    Altair Employee
    Hi,
    Open the starter out (_0000.out) file in Textpad and find the current time step value.
