How to change Max legend color in Simlab Post-processing
User: "alpha_21885"
Altair Community Member
Updated by alpha_21885
Hi,
I would like to edit Max legend color in Simlab post. I can edit value but nothing changes.
In HyperView, I can make this change.
Any advise for this?
1 - 3 of 31
    User: "Nantha"
    New Altair Community Member
    Updated by Nantha
    Hello Alpha
    We are unable to reproduce the issue which you mentioned. I have attached a small video showing the editing of Max legend value and colour using SimLab 2019.3 version.
    Kindly let us know the steps which you have followed in this process. Also if you can share this model, we can identify the cause of this issue as in your case.
    Thanks & Regards
    Nantha Kumar N
    User: "alpha_21885"
    OP
    Thanks Nantha for your information.
    My simulation result is modal frequency response analysis. I am not sure SL 2019.3 support for this.
    User: "Nantha"
    Updated by Nantha
    Hello Alpha
    We tried using Modal Frequency Response results in SimLab 2019.3, but we are unable to reproduce the issue.
    Can you kindly share the model so that we can try to identify the issue.
    Thanks & Regards
    Nantha Kumar N
