Hi all,
I am using the TMS320F280049C control board along with TMDSHSECDOCK to do some testing . I am using the Sim Coder and the code generation functions that PSIM provides for F28004x Target.
I need a specific feature of F280049C which is synchronization to an external signal. I would first need to use Input X-Bar to input the external signal that I want to sync to and secondly, configure the ePWM1 sync input to be either EXTSYNCIN1 or EXTSYNCIN2. These features are described in the control board datasheet, however, I am not able to find a way to configure the second step using PSIM Sim Coder F28004x Target blocks.
Has anyone faced this problem before?
I look forward for your replies.
Thanks,
Denys
