🎉Community Raffle - Win $25
Join and Win
How to apply transient load
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I want to apply load F= x (N) at t=0  and F= Y (N) at t=0.1s, Please help me out..
1 - 3 of 31
    User: "gopal_rathore"
    Altair Community Member
    Updated by gopal_rathore
    Hi ,
    Go to XY plots>>curve editor, create a function there.
    Assign this function ID in the load defined using utility>>boundary conditions
    Altair Employee
    OP
    Hi Ganesh,
    I presume that you are trying to apply a concentrated load (/CLOAD).
    As Gopal mentioned using the curve editor you can create the required function and the same curve has to be recalled in the /CLOAD created. We have an example, Example 18-Square Plate Torsion , in the Help Menu where you can see this application. Please refer the same.
    As a general guideline, normally  starting from a zero load, and zero solution, we gradually ramp up the load until we achieve the desired total load. This gradual ramping up the load from a value close to zero is often a more robust approach for solving nonlinear problems. Also, please go through https://altairuniversity.com/learning-library/7-guidelines-to-apply-quasi-static-load-in-explicit-simulation/ which provides basic guidelines on applying a quasi static load for explicit analysis.
    Altair Employee
    OP
    Thanks George and Gopal
