Altair RISE
Nominate Yourself Now!
Export meshed file from Hypermesh and import into Ansys wb
User: "Dung Nguyen_22269"
Altair Community Member
Updated by Dung Nguyen_22269
Hello everyone,
I am currently having issues related to export and import file.
I unfortunately had meshed a model in Optistruct user-interface, and i do not know the way to change element type among 2 kinds of divergent interfaces.
Then, i failed to import .cdb file into Ansys WB 2019.2.
So, the questions are how could i solve both of those issues?
Many thanks.
1 - 5 of 51
    User: "Rogerio Nakano_21179"
    New Altair Community Member
    Updated by Rogerio Nakano_21179
    Hi
    If I understood correctly you prepared your model within the OptiStruct UI and want to have it set for Ansys.
    One way to achieve that is converting the model from OS to Ansys using the conversion tool within HyperMesh.
    I hope this helps.
    Regards
    OP
    Hello Mr. Nakano,
    Your answer was great.
    To be honest, i am currently not using HW 2020 version. Actually, it is 2017 one.
    So, how could i convert mesh in 2017 ver interface?
    Thanks.
    Hello Mr. Nakano,
    Thanks.
    Hi
    In that case, you will find the convert option in the main drop down menu: 'Tools > convert > OptiStruct >Ansys'
    Let us know that it is helpful.
    Regards
    OP
    Hi
    Regards
    Hello,
    It works efficiently. Thanks for your support.
    Hello,
    Hi
    I am glad that helped you.
    Could you please mark the post as helpful?
    Thanks
