Changing height of DesignSpace during optimization
Hi, I have to optimize the natural frequencie of a component and got for this task a nearly unlimited design space. Only at the top and bottom of the part has to be Connections (plates), so there are nondesign spaces.
To get the optimum in the topology optimization the design space is as big as possible, but with this optimization Optistruct calculate only the optimum in this design space, because the two nondesign spaces at the top and bottom are fixed.
So there is also the possibility that the optimum is somewhere between. To consider that my idea is to use two optimizations like topology and shape.
I have not found a solution how to change the height of my design space with shape optimization. I think Optistruct have to get a start value for example 40mm and an increment like 2mm so it can calculate all Options in any height. Furthermore for this example OptiStruct have to mesh the Designspace every time it Change the height again and automaticaly because otherwise it press the Elements to much togehter.
Is that possible or do you have any other ideas?
Thank you very much!
Thank you very much for your answer. It was very helpful, but I've got a new problem.
My model runs into element quality error, but I think I've Setup the remeshing process with Optimization>>opti control>>set REMESH to 1
What I have to do to run the optimization without element quality error?
Of Course. Thanks for your fast reply
My modell has a Topology and a Shape optimization. If I delete the Shape optimization it runs totaly normal so it's not the Problem of the bad mesh at the beginning. Something is wrong with the Shape optimization.
In the Outputfile stands: 'Total # of elements that failed validity check (error) =530462'
This Elements who failed are all the elements of the part who has to change his shape and it is'nt possible that they are meshed all wrong from the beginning
The optimization runs, thank you very much Prakash.
But I'm not very happy with the results because it seems like OptiStruct ignore the topology optimization.
In my mind I hope that Optistruct takes at first the normal Shape of the part, starts the topology optimization through all iterations. After that it makes the DesignSpace a little bit smaller and starts the topology optimization again and so on. Optistruct should do that till it arrives the smallest Shape.
Do you think it's possible to realize that?
Can you share the .out file for this, please?
Hi @B. Foerster
You can use Move limit available in Shape optimization panel
If at all the optimization runs into element quality error, you can use DOTPRM>>REMESH which meshes the model at current iteration to improve the element quality,
