Optistruct 2022 (error while running a simulation - 3 point bending on a composite test sample)
" *** See next message about line 955 from file:
test_sample(transient_loading).fem
"DCOMP 1 PCOMP"
*** ERROR # 1329 *** in the input data:
There must be at least one PID defined on DCOMP."
I've encountered the following error, although I have created a property defined it. I kindly request your help on this issue.
I have attached images for reference.
Thank you
1 - 1 of
11
i believe you need "stack" type instead of "pcomp" in the Dcomp
