Springs with variable stiffness property
Javid Moraveji
Javid Moraveji Altair Community Member
edited April 2023 in Community Q&A
1) Is there an element type/property available that can represent a nonlinear spring with a variable stiffness as a table?
2) Is there a way to specify the force at the tip of a spring (linear CBush1D or nonlinear as above) to follow the deformation direction of tip Grids when the deflections are large?
Welcome!
Best Answer
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited April 2023 Answer ✓
    Thanks Adriano.
    I played with it and used it.
    I am guessing the answer to my second question is adding FLLWER to my input deck with option 1 for concentrated forces/moments. For the CBUSH example, if I want the force follow the the direction of the spring nodes, do I need to define its direction using a local coordinate system?
    correct. By defining a follower force (FORCE2, if I'm not wrong) you specify 2 nodes as reference for the force direction. If their position changes during the NL run, the force will follow this new direction accordingly.
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited April 2023
    hi,
    both CBUSH/PBUSH and CBUSH/PBUSH1D have the option of using a NL force x displcaement curve (TABLED1) and assign it to the NL stiffness KN;
    /try this one, attached
  • Javid Moraveji
    edited April 2023
    Thanks Adriano.
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    Thanks Adriano.
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited April 2023
    sorry..FORCE1
    https://help.altair.com/hwsolvers/os/topics/solvers/os/force1_bulk_r.htm
Welcome!
Welcome!
