Altair RISE
Nominate Yourself Now!
HyperMesh Segmentation Error
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I first got Error 9 and Error 6. To solve this problem I got a new license file from Altair.
Now a segmentation error occurs when I launch HyperMesh or HyperMesh Desktop.
I placed the license file in C:\Program Files\Altair\2017\security.
I also deleted
  • batchmesher_config in C:\Users\Lars\Documents
  • .Altair in C:\Users\Lars
  • .altair in C:\Users\Lars\AppData\Local\Temp
because I read about segmentation erros in other topics.
Nothing helped so far. What can I do?
Best regards
Lars
1 - 7 of 71
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    You must also hmsettings.tcl, hmmenu.set and command.cmf. also hwsettings.xml in my documents (if that is the working directory), restart the app and try.
    Altair Employee
    OP
    Thank you. It still does not work.
    I deleted
    • C:\Users\Lars\.Altair
    • C:\Users\Lars\AppData\Local\Temp\.altair
    • C:\Users\Lars\AppData\Local\.altair_licensing
    • C:\Users\Lars\AppData\Local\Temp\.Lars_sst_10000_1_tyz
    • C:\Users\Lars\Documents\batchmesher_config.cfg
    • C:\Users\Lars\Documents\hwsettings.xml
    I could not find
    • hmsettings.tcl
    • hmmenu.set
    • command.cmf.
    I started a search on C:\, found and deleted
    • C:\Program Files\Altair\2017\hm\bin\win64\hmmenu.set
    • C:\Program Files\Altair\2017\hw\tcl\hwt\mkWidgets\demos\command.cmf
    • C:\Program Files\Altair\2017\demos\automate\7_hypermesh\BatchMeshing\testfiles\batchmesh\bm_141012_001\command.cmf
    Then I got this
    I can allways completly deinstall the software, install and try again, if you think that helps.
    Altair Employee
    OP
    Anyone an idea?
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    Delete som thing within C:\Program Files\Altair\2017\ is NOT GOOD IDEA  :-)
    So maybe that's the time to reinstall your soft.
    Altair Employee
    OP
    Everything else did not work, so there was nothing to loose. Anyway the problem is not solved.
    I deinstalled the software and installed it again. Still the same error: A segmentation error ocurred.
    By the way: When I start the HyperView Player 2017 I get a Windows notification: Altair HyperView Player hast stopped working - A problem caused the program to stop working correctly. ...
    Altair Employee
    OP
    Hi,
    This seems bit strange. I hope you are using the HyperWorks student version.
    As a workaround can you please clear all the temp files from your system. Then from the Documents folder, which is your working directory, clear all the settings files. Please close all the HyperWorks sessions and delete these settings files.
    Also, please send us the graphics card detais. Paste the output of dxdiag (go to start > run > type dxdiag > enter > copy the display tab/s > send it to us).
    Altair Employee
    OP
    I am using the 'normal' version, because my institution baught a commercial license.
    Display tab output from dxdiag is as following:
    Display Devices
               Card name: Intel(R) HD Graphics 530
            Manufacturer: Intel Corporation
               Chip type: Intel(R) HD Graphics Family
                DAC type: Internal
             Device Type: Full Device
              Device Key: Enum\PCI\VEN_8086&DEV_1912&SUBSYS_06B91028&REV_06
           Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
     Device Problem Code: No Problem
     Driver Problem Code: Unknown
          Display Memory: 8252 MB
        Dedicated Memory: 128 MB
           Shared Memory: 8124 MB
            Current Mode: 1920 x 1080 (32 bit) (59Hz)
             HDR Support: Not Supported
        Display Topology: Extend
     Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
         Color Primaries: Red(0.640148,0.330578), Green(0.300305,0.600109), Blue(0.150891,0.060070), White Point(0.313977,0.329602)
       Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
            Monitor Name: HP 2310 Series Wide LCD Monitor
           Monitor Model: HP 2310
              Monitor Id: HWP288F
             Native Mode: 1920 x 1080(p) (60.000Hz)
             Output Type: HDMI
    Monitor Advanced Color Capabilities: None
    Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
             Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\ki124064.inf_amd64_c15f53d05810a034\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki124064.inf_amd64_c15f53d05810a034\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki124064.inf_amd64_c15f53d05810a034\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki124064.inf_amd64_c15f53d05810a034\igd12umd64.dll
     Driver File Version: 22.20.0016.4771 (English)
          Driver Version: 22.20.16.4771
             DDI Version: 12
          Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
            Driver Model: WDDM 2.1
     Graphics Preemption: Triangle
      Compute Preemption: Thread
                Miracast: Not Supported by WiFi driver
     Hybrid Graphics GPU: Integrated
          Power P-states: Not Supported
       Driver Attributes: Final Retail
        Driver Date/Size: 8/12/2017 4:00:00 PM, 60397088 bytes
             WHQL Logo'd: Yes
         WHQL Date Stamp: Unknown
       Device Identifier: {D7B78E66-5A52-11CF-3B61-A926BDC2DB35}
               Vendor ID: 0x8086
               Device ID: 0x1912
               SubSys ID: 0x06B91028
             Revision ID: 0x0006
      Driver Strong Name: oem0.inf:5f63e53470659c00:iSKLD_w10_DS:22.20.16.4771:pci\ven_8086&dev_1912&subsys_06b91028
          Rank Of Driver: 00D10001
             Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
             DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  DXVA2_ModeVC1_D2010  DXVA2_ModeWMV9_IDCT  DXVA2_ModeVC1_IDCT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT  DXVA2_ModeH264_VLD_Stereo_NoFGT  DXVA2_ModeH264_VLD_Multiview_NoFGT  DXVA2_ModeHEVC_VLD_Main  DXVA2_ModeHEVC_VLD_Main10
       Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                         {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                         {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                         {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                         {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                         {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                         {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                         {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
            D3D9 Overlay: Supported
                 DXVA-HD: Supported
            DDraw Status: Enabled
              D3D Status: Enabled
              AGP Status: Enabled
           MPO MaxPlanes: 1
                MPO Caps: Not Supported
             MPO Stretch: Not Supported
         MPO Media Hints: Not Supported
             MPO Formats: Not Supported
        PanelFitter Caps: Not Supported
     PanelFitter Stretch: Not Supported
               Card name: AMD Radeon(TM) R5 340X
            Manufacturer: Advanced Micro Devices, Inc.
               Chip type: AMD Radeon Graphics Processor (0x6610)
                DAC type: Internal DAC(400MHz)
              Device Key: Enum\PCI\VEN_1002&DEV_6610&SUBSYS_00831028&REV_83
          Display Memory: 10153 MB
        Dedicated Memory: 2029 MB
            Current Mode: 1920 x 1080 (32 bit) (60Hz)
         Color Primaries: Red(0.655773,0.336437), Green(0.325695,0.612805), Blue(0.154797,0.065930), White Point(0.313977,0.329602)
            Monitor Name: Dell P2217H(DisplayPort)
           Monitor Model: DELL P2217H
              Monitor Id: DELA0D8
             Output Type: Displayport External
             Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\c0314337.inf_amd64_21ee54ffe6f42e4c\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\c0314337.inf_amd64_21ee54ffe6f42e4c\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\c0314337.inf_amd64_21ee54ffe6f42e4c\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\c0314337.inf_amd64_21ee54ffe6f42e4c\amdxc64.dll
     Driver File Version: 22.19.0165.0512 (English)
          Driver Version: 22.19.165.512
             DDI Version: 12
          Feature Levels: 11_1,11_0,10_1,10_0,9_3,9_2,9_1
            Driver Model: WDDM 2.2
     Graphics Preemption: DMA
      Compute Preemption: DMA
     Hybrid Graphics GPU: Not Supported
        Driver Date/Size: 5/16/2017 4:00:00 PM, 1675840 bytes
             WHQL Logo'd: Yes
       Device Identifier: {D7B71EE2-2550-11CF-9871-26203FC2DB35}
               Vendor ID: 0x1002
               Device ID: 0x6610
               SubSys ID: 0x00831028
             Revision ID: 0x0083
      Driver Strong Name: oem9.inf:cb0ae41455575dcf:ati2mtag_R501DS:22.19.165.512:pci\ven_1002&dev_6610&subsys_00831028&rev_83
          Rank Of Driver: 00D10000
             Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
             DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT  DXVA2_ModeH264_VLD_Stereo_NoFGT  DXVA2_ModeVC1_VLD  DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC  DXVA2_ModeVC1_IDCT  DXVA2_ModeWMV9_IDCT
       Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
            D3D9 Overlay: Not Supported
                 DXVA-HD: Not Supported
              D3D Status: Enabled
              AGP Status: Enabled
           MPO MaxPlanes: 1
