🎉Community Raffle - Win $25
Join and Win
Radioss Optimization (RADOPT)
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
Is there a standard amount of space there needs to be between the different parameters in a .radopt file. I'm adapting an existing .radopt file (with notepad++), and have tried finding a pattern in the amount of spaces between the parameters of the different cards. However, there doesn't seem to be one.
Any help with this would be appreciated.
Kind Regards
Cedric
1 - 8 of 81
    User: "Simon Križnik"
    Altair Community Member
    Updated by Simon Križnik
    Hi,
    the standard amount of space for different parameters is 10. You can use the following template as a guide (be sure to include the # character at the beginning so solver will know this is a comment):
    The values are aligned to the right i.e. to fill the tenth space (single digit) or ninth & tenth  (double digit) and so on.
    Check the sample radopt file attached
    Altair Employee
    OP
    Hi @Ivan
    Thanks for the quick response. I was already using this template, but didn't know they needed to be aligned to the right.
    I've noticed in the attached file that you use the /BULK/DATA/1 to use BULK Data Inputs from OptiStruct. Do you know if al these Bulk Data Sections are useable? I does not seem to be mentioned in the Radioss Optimization information. They do reference /BULK but don't really give any extra information. (I'm not really familiar with Optistruct but however I do have colleague's that can help).
    All Bulk data input should be supported since optimization is handled by Optistruct in the background. If still uncertain, open the automatically created *.fem file to check if all keywords are present in the Optistruct model.
    Altair Employee
    OP
    Disregard both responses, I found my own mistake.
    Altair Employee
    OP
    repost*
    Altair Employee
    OP
    Can anyone tell me if it's possible to restart a radopt run? I'm dealing with an optimisation which takes a long time for each outerloop so I want to be able to start the run in the evening, end it in the morning and restart it the next evening. I know you can restart a previous radioss runs if the /RERUN card is used, however this will only restart the radioss run not the radopt run.
    I am not sure if a restart is possible, but you can use pause/resume command in HyperWorks Solver View:
    Altair Employee
    OP
    I know this exists, however I need to be able to stop and resume. The HWU's need to be used by other people during the day otherwise I could just keep it running all day and night.
