🎉Community Raffle - Win $25
Join and Win
Error in output results.
RAMGANESHUser: "RAMGANESH"
Altair Community Member
Updated by RAMGANESH
Dear All,
I am working on the seat strength analysis ,my analysis is completed but the structure is deforming more than the expected one.Kindly give your suggestions
Thanks
Ram
1 - 9 of 91
    could you share us input deck?
    OP
    Dear Rahul,
    Kindly find the data below.
        CONTROL  PARAMETERS
        IPRI  : PRINTOUT FLAG . . . . . . . . . . . . . . . .         0
        INVERS: MANUAL VERSION OF THIS INPUT DECK . . . . . .       110
        NSUBS:   NUMBER OF SUBSETS. . . . . . . . . . . . . .         1
        NPART:   NUMBER OF PARTS. . . . . . . . . . . . . . .         8
        NUMMAT: NUMBER OF MATERIALS . . . . . . . . . . . . .         2
        NUMGEO: NUMBER OF PROPERTY SETS . . . . . . . . . . .         5
        NUMNOD: NUMBER OF NODAL POINTS. . . . . . . . . . . .     30635
        NUMSKW: NUMBER OF SKEW REFERENCE FRAMES . . . . . . .         0
        NUMBCS: NUMBER OF BOUNDARY CONDITIONS . . . . . . . .         2
        NUMFRAM: NUMBER OF REFERENCE FRAMES . . . . . . . . .         0
        NUMELQ: NUMBER OF 2D SOLID ELEMENTS . . . . . . . . .         0
        NUMELS: NUMBER OF 3D SOLID ELEMENTS . . . . . . . . .         0
        NUMELC: NUMBER OF 3D SHELL ELEMENTS (4-NODES) . . . .     29402
        NUMELT: NUMBER OF 3D TRUSS ELEMENTS . . . . . . . . .         0
        NUMELP: NUMBER OF 3D BEAM  ELEMENTS . . . . . . . . .         0
        NUMELR: NUMBER OF 3D SPRING ELEMENTS. . . . . . . . .       160
        NUMELTG: NUMBER OF 3D SHELL ELEMENTS (3-NODES). . . .       580
        NUMELX: NUMBER OF MULTIPURPOSE ELEMENTS . . . . . . .         0
        NUMSPH : NUMBER OF SMOOTH PARTICLES (SPH CELLS) . . .         0
        NSPHBCS: NUMBER OF SPH SYMETRY CONDITIONS . . . . . .         0
        NSPHIO : NUMBER OF SPH INLET/OUTLET CONDITIONS. . . .         0
        NFUNCT: NUMBER OF USER'S FUNCTIONS. . . . . . . . . .         2
        NGRAV:  NUMBER OF GRAVITY LOADS . . . . . . . . . . .         0
        NCONLD: NUMBER OF CONCENTRATED LOADS. . . . . . . . .         2
        NINVEL: NUMBER OF INITIAL VELOCITIES. . . . . . . . .         0
        NPRELD: NUMBER OF PRESSURE LOADS. . . . . . . . . . .         0
        NUMBER OF ACCELEROMETERS. . . . . . . . . . . . . . .         0
        NUMBER OF SENSORS . . . . . . . . . . . . . . . . . .         0
        NUMBER OF GAUGES. . . . . . . . . . . . . . . . . . .         0
        NINTER: NUMBER OF INTERFACES. . . . . . . . . . . . .         2
        NRWALL: NUMBER OF RIGID WALLS . . . . . . . . . . . .         0
        NRBODY: NUMBER OF RIGID BODIES. . . . . . . . . . . .         8
        NFXBODY: NUMBER OF FLEXIBLE BODIES. . . . . . . . . .         0
        NCONX : NUMBER OF RIGID LINKS TO MADYMO BODIES. . . .         0
        NODMAS: NUMBER OF ADDED NODAL MASSES. . . . . . . . .         0
        NIMPDISP: NUMBER OF IMPOSED DISPLACEMENTS . . . . . .         0
        NIMPVEL: NUMBER OF IMPOSED VELOCITIES . . . . . . . .         0
        NIMPACC: NUMBER OF IMPOSED ACCELERATIONS . . . . . .          0
        NRIVET: NUMBER OF RIVETS OR SPOT WELDS. . . . . . . .         0
        NSECT : NUMBER OF SECTIONS SAVED (TIME HISTORY PLOTS)         0
        NJOINT: NUMBER OF JOINTS. . . . . . . . . . . . . . .         0
        NACTIV: NUMBER OF ELEMENT DESACTIVATION GROUPS. . . .         0
        NDAMP:  NUMBER OF RAYLEIGH DAMPING GROUPS . . . . . .         0
        NGJOINT: NUMBER OF GEAR TYPE JOINTS . . . . . . . . .         0
        NUMMPC: NUMBER OF MULTI-POINT CONSTRAINTS . . . . . .         0
        NR2RLNK: NUMBER OF EXTERNAL COUPLING LINKS . . . . .          0
        NSUBDOM: NUMBER OF SUBDOMAINS . . . . . .. . . . . .          0
        NVOLU:  NUMBER OF MONITORED VOLUMES . . . . . . . . .         0
        NEIG:   NUMBER OF EIGEN AND STATIC MODES PROBLEMS . .         0
        NGRAPH: GRAPH DEFINITION FOR MULT-LEVEL CONDENSATION.         0
        NBEM:   NUMBER OF BEM SOLVED PROBLEMS . . . . . . . .         0
        NRBE2:  NUMBER OF RBE2 RIGID ELEMENTS . . . . . . . .         0
        NRBE3:  NUMBER OF RBE3 CONSTRAINT ELEMENTS  . . . . .         0
        INITIAL STRESS FILE =
                                              FLAG ISIGI. . .         0
        N2D3D : ANALYSIS TYPE: 0=3D,1=AXISYM,2=PLANE STRAIN .         0
        ANALYSIS OPTIONS
        INTEG8: 8 GAUSS POINT CONDENSED INTEGRATION . . . . .         0
        IPARITH: PARALLEL ARITHMETIC FLAG (2 OFF, 1 0N) . . .         1
        ISUB  : (OLD) SUBCYCLING (1:YES 0:NO) . . . . . . . .         0
        MSHSUB: MEMORY ALLOCATION FOR (NEW) SHELLS SUBCYCLING
                                            (1:YES 0:NO). . .         0
        IUSERW: GENERAL USER WINDOW FLAG. . . . . . . . . . .         0
        ISOLID: DEFAULT BRICK FORMULATION FLAG. . . . . . . .         1
        ISST_S: DEFAULT BRICK SMALL STRAIN FLAG . . . . . . .         0
        IPLA_S: DEFAULT SOLID STRESS PLASTICITY FLAG. . . . .         2
        ISHELL: DEFAULT SHELL FORMULATION FLAG. . . . . . . .         1
        ISST  : DEFAULT SHELL SMALL STRAIN FLAG . . . . . . .         0
        ITHK  : DEFAULT SHELL THICKNESS VARIATION FLAG. . . .         0
        IPLA  : DEFAULT PLANE STRESS PLASTICITY FLAG. . . . .         0
        ISTR  : DEFAULT SHELL STRAIN COMPUTATION FLAG . . . .         0
        ISHEA : DEFAULT SHELL SHEAR COMPUTATION FLAG. . . . .         0
        INSH  : SHELL INERTIA FLAG. . . . . . . . . . . . . .         0
        ISH3N : DEFAULT 3 NODE SHELL FORMULATION FLAG . . . .         2
        NPTS  : SHELL PROPERTIES DEFAULT NUMBER OF
                INTEGRATION POINTS OR LAYERS. . . . . . . . .         0
        ISTRA : DEFAULT SOLID STRAIN COMPUTATION FLAG . . . .         2
        ISHFRAM:LOCAL SHELL FRAME DEFINITION. . . . . . . . .         0
        LAGRANGE MULTIPLIER OPTIONS
        LAGM_TOL:CONVERGENCE CRITERIUM. . . . . . . . . . . . 1.0000000000000E-11
        NODAL MASS DISTRIBUTION FLAG . . . . . . . . .         0
        SPEED PARAMETERS
        STARTER RUNNING ON. . . . . . . . . . . . . . . . . .         1 THREAD
        NUMBER OF SPMD DOMAINS. . . . . . . . . . . . . . . .         1
        NUMBER OF THREADS PER DOMAIN. . . . . . . . . . . . .         1
        ARCHITECTURE OPTIMIZATION . . . . . . . . . . . . . .        22, win64
        SIZE OF ELEMENT BUFFER. . . . . . . . . . . . . . . .       128
        UNIT SYSTEMS DEFINITION
                                                              MASS                LENGTH              TIME
        WORK UNIT SYSTEM . . . . . . ( N.A, N.A, N.A ) 1.0000000000000E+00 1.0000000000000E+00 1.0000000000000E+00
        INPUT UNIT SYSTEM  . . . . . ( N.A, N.A, N.A ) 1.0000000000000E+00 1.0000000000000E+00 1.0000000000000E+00
        LOAD CURVES
        NUMBER OF LOAD CURVES. . . . . . . . =         2
        LOAD CURVE ID . . . . . . . . . . . =         1
        X                   Y
         0.000000000000        1333.330000000
        0.1000000000000        1333.330000000
        0.2000000000000        1333.330000000
        LOAD CURVE ID . . . . . . . . . . . =         2
        X                   Y
         0.000000000000        4000.000000000
        0.1000000000000        4000.000000000
        0.2000000000000        4000.000000000
        TABLES
        NUMBER OF TABLES . . . . . . . . . . =         0
        FUNCTION  TRANSFORMATION
         steel
         MATERIAL NUMBER . . . . . . . . . . . .=         1
         MATERIAL LAW. . . . . . . . . . . . . .=         2
         INITIAL DENSITY . . . . . . . . . . . .= 7.8000000000000E-09
         EOS REFERENCE DENSITY . . . . . . . . .= 7.8000000000000E-09
           ELASTIC PLASTIC LAW
         YOUNG'S MODULUS . . . . . . . . . . . .=  210000.0000000
         POISSON'S RATIO . . . . . . . . . . . .= 0.3000000000000
         SHEAR MODULUS . . . . . . . . . . . . .=  80769.23076923
         JOHNSON COOK MODEL :
         YIELD COEFFICIENT A . . . . . . . . . .=  310.0000000000
         YIELD COEFFICIENT B . . . . . . . . . .=  350.0000000000
         YIELD COEFFICIENT N . . . . . . . . . .= 0.5000000000000
         EPS-MAX . . . . . . . . . . . . . . . .= 1.0000000000000E+30
         SIG-MAX . . . . . . . . . . . . . . . .=  440.0000000000
         ISO-KINEMATIC HARDENNING FACTOR. . . . =  0.000000000000
         STRAIN RATE COEFFICIENT CC. . . . . . .=  0.000000000000
         REFERENCE STRAIN RATE . . . . . . . . .=  1.000000000000
         FLAG FOR STRAIN RATE ON SIG-MAX . . . .=         1
         SMOOTH STRAIN RATE OPTION . . . . . . .=         1
         STRAIN RATE CUTTING FREQUENCY . . . . .= 1.0000000000000E+30
         TEMPERATURE EXPONENT. . . . . . . . . .=  1.000000000000
         MELTING TEMPERATURE K . . . . . . . . .= 1.0000000000000E+30
         SPECIFIC HEAT Rho*Cp. . . . . . . . . .=  0.000000000000
         INITIAL TEMPERATURE K . . . . . . . . .=  298.0000000000
         material1
         MATERIAL NUMBER . . . . . . . . . . . .=         2
         MATERIAL LAW. . . . . . . . . . . . . .=        13
         INITIAL DENSITY . . . . . . . . . . . .= 3.5000000000000E-09
         EOS REFERENCE DENSITY . . . . . . . . .= 3.5000000000000E-09
           RIGID LAW                           ,/       -----------
         YOUNG'S MODULUS . . . . . . . . . . . .=  0.1050E+07
         POISSON'S RATIO . . . . . . . . . . . .=  0.1000E+00
         SHEAR MODULUS . . . . . . . . . . . . .=  0.4773E+06
             PROPERTY SETS
    steeltube
         ISOTROPIC SHELL PROPERTY SET
         PROPERTY SET NUMBER . . . . . . . . . .=         1
         NUMBER OF INTEGRATION POINTS. . . . . .=         0
         POST PROCESSING STRAIN FLAG . . . . . .=         0
         SHELL THICKNESS . . . . . . . . . . . .=  1.500000000000
         SMALL STRAIN FLAG . . . . . . . . . . .=         2
         SHELL FORMULATION FLAG. . . . . . . . .=         1
         3NODE SHELL FORMULATION FLAG. . . . . .=         2
         DRILLING D.O.F. FLAG  . . . . . . . . .=         0
         SHELL MEMBRANE DAMPING. . . . . . . . .=  0.000000000000
         SHELL NUMERICAL DAMPING . . . . . . . .= 1.0000000000000E-02
         SHEAR AREA REDUCTION FACTOR . . . . . .= 0.8333333333333
         SHEAR FORMULATION FLAG. . . . . . . . .=         0
         THICKNESS VARIATION FLAG. . . . . . . .=         0
         PLASTICITY FORMULATION FLAG . . . . . .=         0
    prop3mm
         PROPERTY SET NUMBER . . . . . . . . . .=         2
         SHELL THICKNESS . . . . . . . . . . . .=  3.000000000000
    prop5mm
         PROPERTY SET NUMBER . . . . . . . . . .=         3
         SHELL THICKNESS . . . . . . . . . . . .=  5.000000000000
    prop1mm
         PROPERTY SET NUMBER . . . . . . . . . .=         4
         SHELL THICKNESS . . . . . . . . . . . .=  1.000000000000
    property1
         SPRING PROPERTY SET
         PROPERTY SET NUMBER . . . . . . . . . .=         5
         SPRING MASS . . . . . . . . . . . . . .= 1.0000000000000E-06
         SPRING INERTIA. . . . . . . . . . . . .= 1.0000000000000E-04
         SKEW FRAME NUMBER (0:GLOBAL). . . . . .=         0
         SENSOR NUMBER (0:NOT USED). . . . . . .=         0
         SENSOR FLAG (0:ACTIV 1:DISACT 2:BOTH) .=         0
         FAILURE FLAG (0:UNCOUPLED 1:COUPLED). .=         0
         FAILURE CRITERIUM (DISPL/FORCE/ENERGY).=         0
               1:DISPLACEMENT  2:FORCE  3:ENERGY
         X TRANSLATION
         SPRING STIFFNESS. . . . . . . . . . . .=  1000000.000000
         SPRING DAMPING. . . . . . . . . . . . .=  0.000000000000
         FORCE/DISPL. CURVE NUMBER . . . . . . .=         0
         ABSCISSA SCALE FACTOR ON CURVE . . . . =  1.000000000000
         FORCE/DISPL. CURVE NUMBER 2 (H=4) . . .=         0
         HARDENING FLAG H. . . . . . . . . . . .=         0
         0:ELASTIC   1:ISOTROPIC 2:UNCOUPLED
         4:KINEMATIC 5:UNCOUPLED NL (UN/RE)LOADING
         DYNAMIC AMPLIFICATION FACTOR A. . . . .=  1.000000000000
         DYNAMIC AMPLIFICATION FACTOR B. . . . .=  0.000000000000
         DYNAMIC AMPLIFICATION FACTOR D. . . . .=  1.000000000000
         DYNAMIC AMPLIFICATION FACTOR E. . . . .=  0.000000000000
         DYNAMIC AMPLIFICATION FACTOR IGF3 . . .=  1.000000000000
         DYNAMIC AMPLIFICATION CURVE NUMBER. . .=         0
         DYNAMIC AMPLIFICATION CURVE 2 NUMBER. .=         0
         NEGATIVE FAILURE DISPLACEMENT . . . . .=-1.0000000000000E+30
         POSITIVE FAILURE DISPLACEMENT . . . . .= 1.0000000000000E+30
         Y TRANSLATION
         Z TRANSLATION
         X ROTATION
         MOMENT/ROTATION CURVE NUMBER. . . . . .=         0
         MOMENT/ROTATION CURVE NUMBER 2 (H=4). .=         0
         NEGATIVE FAILURE ROTATION . . . . . . .=-1.0000000000000E+30
         POSITIVE FAILURE ROTATION . . . . . . .= 1.0000000000000E+30
         Y ROTATION
         Z ROTATION
         SMOOTH STRAIN RATE OPTION . . .. . . . =         0
         STRAIN RATE CUTTING FREQUENCY .. . . .=  0.000000000000
           PARTS
    PART:        66,Steeltube_mid
         PROPERTY:         1,steeltube
         MATERIAL:         1,steel
         SUBSET  :         0
     VIRT. THICKN:  0.000000000000
    PART:        67,clamps_mid
         PROPERTY:         3,prop5mm
         MATERIAL:         1,steel
         SUBSET  :         0
    PART:        68,gusset_clamp
         PROPERTY:         2,prop3mm
         MATERIAL:         1,steel
         SUBSET  :         0
    PART:        69,backplate_mid
         PROPERTY:         4,prop1mm
         MATERIAL:         1,steel
         SUBSET  :         0
    PART:        70,flange5mm_mid
         PROPERTY:         3,prop5mm
         MATERIAL:         1,steel
    OP
    Dear Rahul,
    My model is error free and warning free.but the results are seem to be different.kindly give your suggestions.
    Thanks
    Ram
    could you try runing by changing the Cload?If possible share h3d & t01 file.
    OP
    Dear Rahul,
    I had shared the files in your dropbox
    Thanks
    Ram
    Hi Ram,
    Consider increasing the thickness of the below shown in the image or reduce the load.
    Maybe you can do a optimization.
    OP
    Dear Prakash ,
    I had made the design change in that gusset and got the expected results.
    Thanks for the valuable support.
    Thanks
    Ram
    Thanks for the update Ram.
    Dear Prakash ,
    No Problem :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
