Mass limit reached
Ramakiran Maturi
Ramakiran Maturi New Altair Community Member
edited August 2021 in Community Q&A
Hi I'm facing an error of mass limit reached and identified it's causing by type 7 contact I've checked the time step it's correct don't know why it's causing this error tried changing the parameters as requested in previous questions still not resolved. Please help
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited August 2021
    there's no much information here to help you.
    But depending on your type7 configurations, maybe the contact forces are too high, and then your elements are getting severely distorted, causing the characteristic length to reduce drastically, thus, forcing Radioss to add mass to these nodes to compensate and try to keep the timestep control that youhave enforced.
    I believe there are some formulations for the properties that avoid a little bit these severe distortions, but considering reviewing your model around these elements (they are probably listed in the .out file)
Welcome!
Welcome!
