ERROR # 1000 HELP!!!!!!
Altair Forum User
Altair Forum User
Altair Employee
edited November 2020 in Community Q&A
I want to analyze the stress and strain of helical gear pairs.
But I have already set the properties of all the components.
Does anyone have an idea? Help me.Please!
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    blob.png.8218439365b01c483c73dd002b822e92.pngblob.png.c9949bc1fc7dc3ff6beaf51c5555a5b3.pngblob.png.6d16bddf8d7ab714e5e555072272b8c3.png
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    Hi @siyemusu
    The error is coming from RADPRM control card which is not required for a linear static analysis.
    I can see you are trying to simulate gear mechanism with contacts. Please use NLSTAT with LGDISP instead of Linear static analysis.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    Hi @siyemusu
    Hi @ Prakash Pagadala  ,(I don't know how to @ others...)
    Should I delete the RADPRM control card like this?
    <?xml version="1.0" encoding="UTF-8"?>blob.thumb.png.dae0d05aad18ee140294ad9ebd002cf1.png
    And where to set NLSTAT? I'm new to this software.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    Yes, please delete Randprm and try again.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    WARNING:
     The amount of memory allocated for the run is 1601 MB, which
     is larger than the specified (or the default) RAM= 1000 MB.
     This run will use minimum core processing in the solver.
     *** WARNING # 4732
     Grid # 829909 of element # 746316 has been adjusted for CONTACT # 1.
     *** PROGRAM STOPPED: ERRORS DURING ELEMENT QUALITY CHECK.
     A fatal error has occurred during computations:
    Still fail to run.
    I have met this error for many times and I don't know how to deal with it.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    Do ypu have PARAM>>CHECKEL>NO?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    yes,I do.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    <?xml version="1.0" encoding="UTF-8"?>blob.thumb.png.b1c8a06549d81957c8e3fed03d4e4268.png
  • Altair Forum User
    Altair Forum User
    Altair Employee
    here is the hm file.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    Hi,
    The element quality is too bad and the violates basic qualities. You may have to remesh the components,
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    Hi,
    OMG! Is there any other ways to ignore this problems and get the stress nephogram?
    I'm sorry the time is running out.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    I am sorry about that, but I need some time to investigate.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    anyway,thank you very very much.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    Hi @siyemusu
    Use ELEMQUAL>> TETRA>> TWIST ANGLE>> with an upper bound of 100 and check if that helps.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    Hi @siyemusu
    I have remeshed the components and succeed to run the results.
    Thank you for your help.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    Thank you for the update. Remeshing is a good option over tweqking the element quality values as it may produce weired results
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    I met a problem.I used 'solid edit' to spit the gears and then meshed. Now I want to merge the elements as a whole.How to merge?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    Hi,
    If the elements are in different components, you can use Organize panel(shift+f11) to move the element to a single component,
    Also, make sure the elements are connected nodally.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    Hi,
    The elements are not connected nodally.I want to use interfaces. The element type should be stick or freeze?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2018
    Depends, Freeze will make sure that relative displacement between the nodes is zero,
    Stick is a situation where nodes/elements from both components come in contact and stick to each other after that.
Welcome!
Welcome!
