Bushing creation
Hi everyone,
I am trying to model a bushing in a single plate using HyperMesh. Initially, I created RBE2 elements around the hole and intended to create a bushing between two nodes. However, since I have only a single plate and need to use CBUSH elements for the bushing, I am unsure how to proceed.
Could you provide detailed guidance on how to properly create and connect CBUSH elements in this scenario?
- First, I created rigid elements around the holes and connected them using CBUSH.
- Second, I first created a beam element between the two holes. Then, from one end of the beam to the rigid elements, I created a CBUSH, setting its distance to zero at both ends.
Hi Parthiban,
Usually, CBUSH is created between two components, and you can assign PBUSH properties for them where you can define the spring stiffness.
Follow the below link for this.
FE Modeling of Bolt using CBUSH and RBE2 (youtube.com)
Thanks
Rajashri
Thanks for the Reply Rajashri,
In this case I am trying to model bush in a single plate. Where there is no second component to connect.
What can I do in this case?
Also another Doubt, In this picture representation, which will be appropriate for apply bushing between two components, first or second?
Both the methods are correct in their own way. In the 2nd one it is good use Beam element in the middle instead of rigid.
Thanks
Rajashri
Hi Parthiban,
Thanks
Rajashri
Hi Parthiban,
Thanks
Rajashri
