Bushing creation
Hi everyone,
I am trying to model a bushing in a single plate using HyperMesh. Initially, I created RBE2 elements around the hole and intended to create a bushing between two nodes. However, since I have only a single plate and need to use CBUSH elements for the bushing, I am unsure how to proceed.
Could you provide detailed guidance on how to properly create and connect CBUSH elements in this scenario?
