🎉Community Raffle - Win $25
Join and Win
Sandwich Analysis
Hi There ,
I'm engaged in the project of chassis design for a vehicle for the FSAE competition and i have to make the chassis with a sandwich (CFRP - Foam) material , since hyperworks (OPTISTRUCT) will  help doing the analysis , i started making a plate and making plies with CFRP (MAT8) and PCOMPP card image then a Core(MAT1)  with PSOLID property , also i make laminate with the plies . i applied the load with constrains then loadstep with both and i check CSTRAIN and CSTRESS Properties for the analysis but since i start the analysis there is no iterations made and only the one displacement result appear , i tried alot to change in the structure but still no iterations ,
Here is what i have and there is a copy of the hm file attached
The Results
Iteration Subcase     Variable  Grid/Elem ID   Value
   0    1 MaxDisp                    12205  -0.285887E-02
   0    1 MaxStress                   5725   -15.0120
The amount of memory allocated for the run is 331 MB.
 This run will use in-core processing in the solver.
 ANALYSIS COMPLETED.
 ==== End of solver screen output ====
 ==== Job completed ====
1 - 11 of 111
