Sandwich Analysis
Hi There ,
I'm engaged in the project of chassis design for a vehicle for the FSAE competition and i have to make the chassis with a sandwich (CFRP - Foam) material , since hyperworks (OPTISTRUCT) will help doing the analysis , i started making a plate and making plies with CFRP (MAT8) and PCOMPP card image then a Core(MAT1) with PSOLID property , also i make laminate with the plies . i applied the load with constrains then loadstep with both and i check CSTRAIN and CSTRESS Properties for the analysis but since i start the analysis there is no iterations made and only the one displacement result appear , i tried alot to change in the structure but still no iterations ,
Here is what i have and there is a copy of the hm file attached
The Results
Iteration Subcase Variable Grid/Elem ID Value
0 1 MaxDisp 12205 -0.285887E-02
0 1 MaxStress 5725 -15.0120
The amount of memory allocated for the run is 331 MB.
This run will use in-core processing in the solver.
ANALYSIS COMPLETED.
==== End of solver screen output ====
==== Job completed ====
Answers
Hi mmramadan,
The analysis is completed and you can view the results.
I don't see any errors
0 -
Thanks prakash , but why i can't see more than one iteration for the analysis ?!
0 -
Yes, because you are only running analysis and not optimization, ryt?
0 -
I've changed only the magnitudes of the loads and then when i run the optimization analysis i got the same thing again , i attached an image of the results also
0 1 MaxDisp 10854 0.185177
0 1 MaxStress 13171 -0.115659E+070 -
Hi,
Can you share the model files please?
Use the dropbox link in my signature below to share the files.
0 -
Done
0 -
Hi,
I have your model with me but I dont see any optimization parameters in your model. So that is why only analysis is done instead of Optimization.
0 -
So please could you give me an example to apply an optimization parameter
0 -
Hi,
Did you define any Design variable , design Response , design constraint or Design Objective?
If not please refer Optistruct optimization tutorials.
Regards
Rahul R
0 -
Hi mmramadan
i am designing a chassis for FSAE competition in China.
i think i am facing the same problem with yours and i do not know how to solve this.
could you please tell me how did you solve your problems
thanks for the help:)
0 -
0
