How to Apply load case limits?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
As a part of structural simulation of an helicopter wing, I have calculated all my lift and drag forces and submitted the job for max lift and drag conditions. I observed a max displacement of 5000 mm which in practical case is not possible. Since I gave only Elastic properties, this happened. In the process of understanding the BC of my problem, I found this tutorial 'http://www.altairhyperworks.com/training/self_paced/os_linear/content/linear_3/PDF/Exercise 3a.pdf' similar to my problem..
Here they have mentioned a meaning full DESIGN Criteria in the problem. How so I include this to my simulation?
and for Static linear, my simulation result file shows results in 25 frames, deviations are minimal in first frame of the results... How do i extract result values from different frames (able to view results only for Min and Max values)
