I am able to produce all the graphs. However I am stuck with interaction part. Please help me with this. I have added a video and my code for the reference. Let me know if some information is required from my side.
Hi Himansu - based on your Python code in the file code.txt, I conclude that you are using the Python library "Altair" which is creating visualizations using the Vega library. This software is unrelated to Altair Engineering.
Hi. I see in the video you attached that you are using Panopticon BI. I will ask someone with expertise in Panopticon BI to provide some information.
