unusual issue by running HW and License Problem
Hello all,
at first sorry for my poor englich.
i downloaded HW14.0 Student- Edition to run motionview and motionsolve, also ich got a node locked license for Student Edition. i installed HW14.0 Stu-Edition successfully and placed it in the security folder within the installation folder. everything is ok.
Then i ran HW14, it came a application problem
Details
list element in quotes followed by 'nur' instead of space
while executing
'llength $pairs'
(procedure '::msgcat::mcmset' line 4)
invoked from within
'::msgcat::mcmset de {
'Rigid Body on Lines' 'Starrkörper auf Linien'
'Rigid Body on Surfaces' 'S...'
(in namespace eval '::b3d' script line 205)
invoked from within
'namespace eval ::b3d {
'Dimension Mode' 'Vermessungsmodus'
'Material Database' ...'
(file 'F:/Software/Altair/14.0-edu/hm/scripts/BasicFEA/languages/de.msg' line 2)
invoked from within
'::source -encoding utf-8 F:/Software/Altair/14.0-edu/hm/scripts/BasicFEA/languages/de.msg'
('uplevel' body line 1)
invoked from within
'uplevel 1
(procedure '::msgcat::mcload' line 10)
invoked from within
'::msgcat::mcload $msg_directory'
(procedure '::b3d::L10n::SetLocale' line 14)
invoked from within
'::b3d::L10n::SetLocale '''
(in namespace eval '::' script line 4)
invoked from within
'# Compiled -- no source code available
error 'called a copy of a compiled script''
invoked from within
'tbcload::bceval {
TclPro ByteCode 2 0 1.7 8.5
14 0 132 24 2 0 84 1 4 14 14 -1 -1
132
f!!!!#-<<!+f+pv+K&s!*V!S7&-<<!)9N<!3fAs!5v!!!C!!!!gF#!!)`vpv1l8X!...'
(file 'F:/Software/Altair/14.0-edu/hm/scripts/BasicFEA/main.tbc' line 14)
invoked from within
'source $rootname.tbc'
(in namespace eval '::UserProfiles::BasicFEA' script line 7)
invoked from within
(procedure '::hwt::SourceFile' line 1)
invoked from within
'::hwt::SourceFile $path3/BasicFEA/main.tcl'
(procedure '::UserProfiles::BasicFEA::PanelProc' line 47)
invoked from within
then i click OK and chose die Motionview-icon, however i find that Motionview and Motionsolve can run perfect. i have tried many times wenn i run HW in a month, this issue occurred everytime. because i can run Motionview and Motionsolve so i forget it and let it
These days i learn co-simulation using simulink and motionsolve, i want to use a xml file that i can put it into simulink-S funktion. so at first i run a simulation with my own model and generate a xml file. then i try to run it by motionsolve,like tutorial MV 7002. unfortunately, it occurred another issue
so i dont unterstand what is happend, accualy before this happend, i have puted some xml files into simulink-S funktion but simulink always can`t run a cosimulation because of a error' input xml file is not accessible', through i have set environment variable and matlab path. so i guess ,this licence issue is a big unusual problem against my cosimulation-work using simulink and run xml file using motionsolve
today i have read basic licence troubleshooting and used the command to get my physical adress, i use a pc with system Win10 64bit
C:\Users\Kan>ipconfig/all
Windows-IP-Konfiguration
Hostname . . . . . . . . . . . . : Zack
Primäres DNS-Suffix . . . . . . . :
Knotentyp . . . . . . . . . . . . : Hybrid
IP-Routing aktiviert . . . . . . : Nein
WINS-Proxy aktiviert . . . . . . : Nein
Ethernet-Adapter LAN-Verbindung:
Verbindungsspezifisches DNS-Suffix:
Beschreibung. . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physische Adresse . . . . . . . . : 00-08-02-E6-1D-FC
DHCP aktiviert. . . . . . . . . . : Ja
Autokonfiguration aktiviert . . . : Ja
IPv6-Adresse. . . . . . . . . . . : 2a02:908:4e0:fda0:208:2ff:fee6:1dfc(Bevorzugt)
Lease erhalten. . . . . . . . . . : Donnerstag, 28. Juli 2016 23:20:25
Lease läuft ab. . . . . . . . . . : Freitag, 29. Juli 2016 00:24:25
IPv6-Adresse. . . . . . . . . . . : 2a02:908:4e0:fda0:757d:9711:dfdf:ca51(Bevorzugt)
Temporäre IPv6-Adresse. . . . . . : 2a02:908:4e0:fda0:bcb6:a5ab:c610:414a(Bevorzugt)
Verbindungslokale IPv6-Adresse . : fe80::757d:9711:dfdf:ca51%5(Bevorzugt)
IPv4-Adresse . . . . . . . . . . : 192.168.0.14(Bevorzugt)
Subnetzmaske . . . . . . . . . . : 255.255.255.0
Lease läuft ab. . . . . . . . . . : Freitag, 29. Juli 2016 23:20:23
Standardgateway . . . . . . . . . : fe80::ce35:40ff:fe29:e1a3%5
192.168.0.1
DHCP-Server . . . . . . . . . . . : 192.168.0.1
DHCPv6-IAID . . . . . . . . . . . : 234890269
DHCPv6-Client-DUID. . . . . . . . : 00-01-00-01-18-3B-88-50-00-08-02-E6-1D-FC
DNS-Server . . . . . . . . . . . : 2a02:908:2:a::1
2a02:908:2:b::1
192.168.0.1
192.168.0.2
NetBIOS über TCP/IP . . . . . . . : Aktiviert
Tunneladapter isatap.{523E55D6-2B14-4E33-A44F-D62361A67184}:
Medienstatus. . . . . . . . . . . : Medium getrennt
Beschreibung. . . . . . . . . . . : Microsoft ISATAP Adapter
Physische Adresse . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP aktiviert. . . . . . . . . . : Nein
Tunneladapter LAN-Verbindung* 2:
Beschreibung. . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
IPv6-Adresse. . . . . . . . . . . : 2001:0:5ef5:79fb:ce7:a7a:dae7:63be(Bevorzugt)
Verbindungslokale IPv6-Adresse . : fe80::ce7:a7a:dae7:63be%6(Bevorzugt)
DHCPv6-IAID . . . . . . . . . . . : 100663296
NetBIOS über TCP/IP . . . . . . . : Deaktiviert
C:\Users\Kan>getmac
Physisch. Adresse Transportname
00-08-02-E6-1D-FC Nicht zutreffend
here the licence info
so i find that licence is ok, version=14 and ETHERNET 000802E61DFC are also OK..but the MAC adress is 'not applicable' (german:nicht zutreffend) by using getmac
who can tell me, what can i do to fix these, i need your help....
thank you
Hello,
the first issue is related to starting HyperWorks with the BASIC FEA User Profile. This will lead to the error message as you deacribed. To avoid, please select a different User Profile (e.g. OptiStruct) and then close and restart the HyperWorks Student Edition.
The second error is a license error, probably due to the fact that the HyperWorks Student Edition does not support Co-Simulation with Simulink yet. You would need to use the full license of your university and a full installation of HyperWorks 14 to run the Co-Simulation. Please contact your university advisor or us in order to get access to a full license of HyperWorks.
Jan
Hello,
Jan
Thank you Jan
I have used the full license to run HW14.0 in my uni with MV7002-Cosimulation with Simulink. But the save error appeared everytime..
See hier
i have added the xml full path..but it didn't help
have you any idee? thanks a lot!
This may occur if there are quotes in materials names or other collector names. Remove quotes in material names etc and let us know if it helped
