Catia node to hyperworks
Hello, I have a trouble with node transfer.
I was modeling in CATIA as lots of nodes, and I want to transfer the nodes from CATIA to hyperworks.
When I transfer the nodes to hyperworks (igs file), it is not work as a node. just a point.
there's no x,y,z coordinate and I can't select the nodes.
It takes a lot of time to stamp the nodes by myself.
Is there any way to transfer the nodes from CATIA to hyperworks directly?
Thank you.
@James Kim
Do you mean FE nodes?
Not sure about CATIA FE nodes and the supported formats for the same.
