Catia node to hyperworks
Hello, I have a trouble with node transfer.
I was modeling in CATIA as lots of nodes, and I want to transfer the nodes from CATIA to hyperworks.
When I transfer the nodes to hyperworks (igs file), it is not work as a node. just a point.
there's no x,y,z coordinate and I can't select the nodes.
It takes a lot of time to stamp the nodes by myself.
Is there any way to transfer the nodes from CATIA to hyperworks directly?
Thank you.
Hmm actually, I don't know what is FE nodes..
Pic 1 is what I want to be moved from CATIA to hyperworks,
Pic 2 is what the nodes actually are transfered.
Pic 3 is what I want to see on hyperworks.
HI,
Go to Create nodes panel (shortcut is F8) and select On Geometry option. Select all points by double-clicking on Points selector and select ALL... Click create.
This will create nodes on selected points.
Wow great.. Thanks a lot ! /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
@James Kim
Do you mean FE nodes?
Not sure about CATIA FE nodes and the supported formats for the same.
