🎉Community Raffle - Win $25
Join and Win
** ERROR IN PART (PROPERTY) IN PART NB 1 PROPERTY SET NB 1 DOES NOT EXIST
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello, everyone.
I am a new student learning how to use Hyperworks Block Format to make thermal expansion simulation.
Sorry to write mails to bother you.
I just want to make a thermal expansion simulation.
First I used MAT1 and checked the /HEAT/MAT.
Second I used the /Therm_Stress/MAT as the property. ( /Therm_Stress/MAT can be only chosen in Property.)
I also used the imposed temperature for part of my model.
But After setting the engine file tool, I got the error below.
** WARNING IN MATERIAL DEFINITION
.. NODES
ERROR id : 178
IN PART NB 1
** ERROR TRAPPED : REPORT TO LISTING FILE
** ERROR TRAPPED
What does this mean? What is the Property Set NB 1?
Thank you so much.
Best wishes.
1 - 3 of 31
    Altair Employee
    OP
    check if there is any property assigned to the part/component with name NB in your model.
    if not please do apply.
    Altair Employee
    OP
    Hi. I have come across the same error and I have solved the problem in the following way:
    first of all, I created a midsurface on the component named 'comp_name' with id 33 (bear in mind this number 33). Hence, I got a new component named 'Middle Surface' and I created the mesh on the component 'Middle surface'. Once I would run the analysis, I would get the error
    ERROR id : 178
    IN  PART NB 33
    I tried to delete the component with the id 33 named 'comp_name' and the analysis worked.
    The question is: why?
    Altair Employee
    OP
    Hi Mirino,
    Can you check where elements are organized after meshing?
    is it in mid surface component or in comp_name?
    Also, components should have \PART card image in RADIOSS.
