FSI problem
Hi,
I'm having problem with transfer radioss result of modal analysis (eigenmode) into model in AcuConsole. Animating of radioss result show different scale with model in AcuConsole. Then, when transfer AcuConsole suddenly shutdown.
I'm suspecting the different of default unit used between both solver which cause different scale.
Radios unit:-
kPa
density = tonne/mm^3
AcuConsole unit:-
Pa
density = kg/m^3
Anyone have idea how to solve this?
Can or not rescale radioss result into compatible AcuConsole unit? Or need to run modal analysis with acuconsole unit?
Thanks
Hi,
I'm studying FSI loadcase using own model and having few problems. Need recommendation or idea how to solve this.
1) AcuConsole stop running and shut down suddenly when transfer 'simple BC' from Radios result in Eigenmode Manager. What could be happened?
2) I'm having below error when acuPrep is running, any idea what is the problem?
AcuConsole' Eigenmode Manager has the option of scaling, however I have never used it.
I would suggest using Meter, Kilogram, Seconds for the OP2 file using OptiStruct.
