Altair RISE
Nominate Yourself Now!
Points in a different coordinates system
User: "CdricCd"
Altair Community Member
Updated by CdricCd
Hi,
I'd like to create points in a different coordinates system than the origin one but I can't find the option.
For example I create a marker, I orient it with angles compared to the origin, then I would like to create points in the coordinate system of the new marker. How can I do it without doing manually all the cosinus/sinus transformations ?
Thanks !
1 - 4 of 41
    User: "Praful"
    Altair Employee
    Updated by Praful
    Hello -
    You should be able to do this by using the 'Parametric Points' tool.
    In 2017.2,  it is available in the side toolbar as shown in the attached image
    Regards
    Praful
    User: "CdricCd"
    OP
    Updated by CdricCd
    Oh nice I totally forgot about that option !
    Thanks for the rapidity !
    Regards
    User: "Praful"
    Altair Employee
    Updated by Praful
    You are welcome :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Note that, this is kind of a macro tool, that helps in creating points in relation to a marker. Ultimately, the point coordinates in the panel are represented through functions called as location functions such as loc_rel_to, loc_cylindrical etc..
    Once these points are created, any modification needs to be done in the panel, by editing these function expressions.
    Regards
    Praful
    User: "CdricCd"
    OP
    Updated by CdricCd
    Ok thanks for the tip !
