Altair RISE
Nominate Yourself Now!
Apply Enforced Displacment
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi there,
I'm new at Hypermesh and I was wondering how to apply an enforced displacement as BC?
I've created a load collecter for my 'normal' constraints, and another one for my SPCD constraints, where I put dof3 on 25 for a displacement of 25mm. I've read, that I have to create another SPC with the same settings as the SPDC. But How do I merge the constraints for the SPC loadcase? And when I apply the SPCD constraints and the SPC constraints with the dof3 setting then following error appears:
  *** ERROR # 176 ***
  A dependent d.o.f. of rigid elements is constrained in an SPC set.
Can someone help me?
1 - 17 of 171
    Altair Employee
    OP
    Hi Xone92,
    Looks like you are applying an enforced motion on a dependent node of rigid element which is not allowed.
    SPC should be applied on the same node as SPCD with same DoF checked as marked for SPCD.
    Altair Employee
    OP
    Ah Nice! Thank you! That was the problem image/emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'>
    Altair Employee
    OP
    Hi prakash
    Can you shared me any of the example model of enforce displacement. Which is to define the displacement in SPC.
    Altair Employee
    OP
    Altair Employee
    OP
    grear thanks prakash.
    I am facing lot of problem with press fit analysis. If possible do have any example model please share me....
    Altair Employee
    OP
    @dineshreddy
    I think already an example was shared with you. What problems are you facing?
    Let us know about the problems and we will try our best to help you :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
    Altair Employee
    OP
    Hi prakash,
    Is there any example model which we can apply self + acceleration  load case. How can we apply that and genrally it is for Trim  component.
    Altair Employee
    OP
    Hi Dinesh,
    can you explain what do you mean by Self+acceleration?
    Altair Employee
    OP
    When I want to import fem file into hypermesh, I am receiving this error:
    The file specified is not a Hypermesh database
    How can I import fem file into hypermesh?
    Altair Employee
    OP
    you need .hm file fo that.
    Altair Employee
    OP
    How can I open fem file in hypermesh?
    Altair Employee
    OP
    I want to apply four displacement boundary condition to the attached model in hypermesh (I am working in Optistruct). Please, help me out or explain how I can achieve it:
    x_disp = x displacement
    y_disp = y displacement
    x_coord = x coordinate
    y_coord = y coordinate
    1. (x_coord = 100, y_coord = 35), (x_disp = 2.754, y_disp = -2.345)
    2. (x_coord = 100, y_coord = 40), (x_disp = -3.754, y_disp = -1.345)
    3. (x_coord = 15.3, y_coord = 100), (x_disp = 1.34, y_disp = 2.345)
    4. (x_coord = 15.3, y_coord = 13.4), (x_disp = 2.34, y_disp = 1.345)
    Thank you.
    Altair Employee
    OP
    Hi Samuel,
    Some of the coordinates which you specified are no where near the structure. Please check
    Anyways you can use specify enforced dispalcement using SPCDs. Please search for SPCD/enforced displacement on forum for related posts.
    Altair Employee
    OP
    I still do not understand. Could you please help add enforced displacement (-0.167, 1.234) on the node at the upper right corner of the model. Alternatively, briefly explain how to locate the node and how to apply such enforced displacement
    Altair Employee
    OP
    This is the new error when I attempted to use enforced displacement:
    *** ERROR # 186 ***
     An SPCD component must be constrained by an SPC or SPC1 data.
          GRID ID = 33
        component = 3
      LOAD set ID = 7
       SPC set ID = 1
       subcase ID = 1
    Altair Employee
    OP
    Hi,
    Constrain SPCD nodes with SPC with same Dofs as SPCD.
    Here is a test file
    User: "GHASSEN BEN-AMOR"
    New Altair Community Member
    Updated by GHASSEN BEN-AMOR
    To open fem file, you have to go to File -->import -->solver deck ;)
