Altair RISE
Nominate Yourself Now!
TABLED1 data entry
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Please help me on TABLED1 entries. I am not able to understand how to assign values in this table (help is not clear). If I want to assign random values can I do it or not. Say in Element flux I want to enter values as
for time = 0 sec value is 4.2
for time = 4 sec value is 0
for time = 4.5 sec value is 4.2
for time = 8 sec value is 0
for time = 8.5 sec value is 4.2. and so on to say 16 sec or 24 sec or more.
Can I input these types of random values to TABLED1 Card or not.
1 - 18 of 181
    Altair Employee
    OP
    Hi,
    From Help:
    Discontinuities may be specified between any two points except the two starting points or two end points.  For example, in Figure 1 discontinuities are allowed only between points x2 through x7.  Also, if y is evaluated at a discontinuity, the average value of y is used.  In Figure 1, the value of y at x = x3 is y = (y3+y4)/2.
    3.
    At least one continuation entry must be specified.
    Can you make changes to your table as per the above and check if you can get results you desired?
    Altair Employee
    OP
    Thanks for the reply sir. I have to apply a heat flux as (Need to apply this practically as per the problem statement)
    at time = 0 sec, Heat Flux = 4.2e6 W/m2
    at time = 4 sec, Heat Flux = 0 W/m2
    at time = 45 sec, Heat Flux = 0 W/m2
    1. What I have entered in TABLED1 is
    x1 = 0, y1 = 1 (Linear)
    x2 = 4, y2 = 0 (Linear)
    x3 = 45, y3 = 0 (Linear)
    After I entered these I didn't get the right results.
    2. And when I give values as below still didn't get the correct results:
    x1 = 0, y1 = 4.2e6
    x2 = 4, y2 = 0
    x3 =45, y3 = 0
    Maybe there is something else wrong in my model but I first want to conform this whether this is correct or not the above two tables which I input.
    Please give your inputs
    Altair Employee
    OP
    Hi,
    can you make the following changes and check if you are able to get results?
    x1=0  y1=4.2e6
    x2=2  y2=4.2e6
    x3=4  y3=2
    x4=20  y4=0
    x5= 40  y5=0
    x6=45  y6=0
    Altair Employee
    OP
    I have tried the above values it didnt work out sir. The values of temperature are in 9.99e5 ranges. May be something is terribly wrong in my problem but I have used the same procedure as given in tutorial OS-1090. Please suggest me something. Working on brake disc transient thermal behaviour. Boundary condition are ambient at 22 degree. Covection through disc surface. And heat flux on both discs. I can share model with you if you want.
    Altair Employee
    OP
    Hi Shanky,
    can you share your model?
    Please use the dropbox link in my signature to share the model.
    Altair Employee
    OP
    I have sent you the model files Sir. From- ishan.aggarwal1987@gmail.com
    Altair Employee
    OP
    Thank you for sharing the files.
    I will investigate and get back to you ASAP image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    Altair Employee
    OP
    Hi....
    if i want to do pretension for 1st 0-20 sec and next 20-100 sec for modal analysis then how i should define the table and  load step?
    Please help in this regards.
    thank you
    Altair Employee
    OP
    Hi Prajwal,
    Could you please let me know what is the objective of such setup?
    Modal analysis is not time dependent.
    Altair Employee
    OP
    Hi Sir,
    I was simply trying different scenario..
    can we control pretension in model?(like time dependent)
    if I add time in pretension, Is that the model become Nonlinear?
    Thank you
    Altair Employee
    OP
    Hi,
    Please check this tutorial:
    RD-T: 3510 Cantilever Beam with Bolt Pretensioner
    User: "durukanbdilek"
    Altair Community Member
    Updated by durukanbdilek
    hello admins
    I use materialss have frequency-dependent properties
    I would like to enter E, G, netar data as .txt
    but got error
    can you help me
    Mr @RAHUL
    I have encountered TABLED1 entering error
    '  Discontinuities are not allowed at TABLEM1 endpoints.'
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    As the error clearly indicates there are discontinuities in the table.I presume you have two different load values at the same time/frequency which is not allowed.
    Please check the time data and filter it out to a valid input. If x is identical, you get an error.
    I work on frequency domain and I have not data on time domain
    when data on convert to any plot I cannot see any discontinuities
    on the other hand, I have only material datas for frequency dependent materials which you know
    Can you share the Tablem1 end points?
    at 1000 Hz 232E5 for E (young Modulus)
    at 1000 Hz 2386233 for G (Shear Modulus)
