Altair RISE
Nominate Yourself Now!
Hyperworks CFD License Error Code: 9 when Run(Process type: AcuSolve) is starting
User: "NiklasR"
Altair Community Member
Updated by NiklasR
Hi,
i have the Problem that i get a Error when i will run a Simulation in Hyperworks CFD 2021 Student Version. The following picture show the Log File.
I dont know what can i do because the Mesh will created perfect and under "File->Licensing->Local File" is written "Activated".
I hope somebody can help me.
Thanks in advance.
1 - 5 of 51
    User: "acupro"
    Altair Employee
    Updated by acupro
    Is your HyperWorks CFD Solvers also the student edition?  I just got the EDU version and license today and it works fine for me:
    acuRun: "C:/Program Files/Altair/2020/hwcfdsolvers/acusolve/win64/bin/acuSolve".exe -np 1 -nt 3
    acuSolve: Successfully checked out HyperWorksEDU for Acusolve
    Are you sure you're pointing to the correct HyperWorks CFD Solvers installation from the installer downloaded from the EDU email?
    It's also possible that the correct license is not being used by the solver (possibly different from how the GUI accesses the license).  If you are able to create an Environment Variable, please create one whose name is:
    ALTAIR_LICENSE_PATH
    and whose value is:
    C:\Users\ritte\Documents\altair_lic.dat
    and see if then the license will check out properly.  You may need to save your model, close/exit and restart HyperWorks CFD for it to 'take'.
    User: "acupro"
    Altair Employee
    Accepted Answer
    Updated by acupro
    Seems the solver cannot access the license specified/activated in that pop-up window.  You'll either need to set the environment variable or place the altair_lic.dat file into the
    C:\Program Files\Altair\2020\security
    or
    C:\Program Files\Altair\2021-edu\hwdesktop\security
    directory.
    User: "Junta_20361"
    New Altair Community Member
    Updated by Junta_20361
    could you make a test run using 4 cores?
    i think the EDU license limits the number of cores up to 4. so you cannot run with 24 cores.
    User: "NiklasR"
    OP
    Updated by NiklasR
    Thank you for trying to help me.
    But also the student version allows me to calculate with 24 threads. The problem was the save path of the license file.
    User: "NiklasR"
    OP
    Updated by NiklasR
    or
    directory.
    The Problem was the save path of the license file. After i added it to the
    "C:\Program Files\Altair\2020\security" path
    it works fine.
    Thank you very much!
