🎉Community Raffle - Win $25
Join and Win
Get nodeset from node id
User: "Akash Purushothaman"
Altair Community Member
Updated by Akash Purushothaman
I need to get the list of all nodesets which has a particular node id in its children.
Is there any TCL API that could help achieve this?
1 - 4 of 41
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    I believe you can work with references API.
    hm_getcrossreferencedentities
    Finds entities that reference the specified entity.
    hm_getcrossreferencedentities entity_type entity_name_or_id reference_flag output_mark_id string_array number_of_strings ?search_type? ?exclude_regions?
    HyperMesh Tcl Query Command
    Finds entities that reference the specified entity. This includes collected references, data name references and attribute entity references. Each type of entity that references the specified input entity is returned in a list, and the found entities are then placed on the specified mark for those entity types. See the list of supported entities for this command.
    entity_type
    The type of entity to query.
    entity_name_or_id
    The name or ID of the entity.
    reference_flag
    The type of cross-reference entities to find. Bit values are used and the value is calculated as (Bit0 + 2*Bit1 + 4*Bit2).
    Bit0
    0 - Do not consider collected entity cross-references.
    1 - Consider collected entity cross-references. If the specified entity is not a collected entity, nothing will be returned for this bit.
    Bit1
    0 - Do not consider data name entity cross-references.
    1 - Consider data name entity cross-references. If the specified entity is not referenced by any data names, nothing will be returned for this bit.
    Bit2
    0 - Do not consider attribute entity cross-references.
    1 - Consider attribute entity cross-references. If the specified entity is not referenced by any entity attributes, nothing will be returned for this bit. Only entities for the currently loaded template are considered.
    output_mark_id
    The ID of the mark to place the found cross-referenced entities on. Valid values are 1 and 2.
    string_array
    Reserved for future use. Must be set to 0.
    number_of_strings
    search_type
    By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. Valid values are:
    -byname - Search only by name.
    -byid - Search only by ID.
    exclude_regions
    0 - Include region entities in the search (default).
    1 - Exclude region entities in the search.
    Examples
    To get all entities that cross-reference component with ID 100 on mark 1 and highlight them on the screen:
    foreach entity_type [hm_getcrossreferencedentities comps 100 7 1 0 0 -byid] {
    hm_highlightmark $entity_type 1 h
    To get only collected entity cross-references for component with ID 100 on mark 2:
    hm_getcrossreferencedentities comps 100 1 2 0 0 -byid
    To get only data name entity cross-references for component with ID 100 on mark 1:
    hm_getcrossreferencedentities comps 100 2 1 0 0 -byid
    To get only attribute entity cross-references for component with ID 100 on mark 1:
    hm_getcrossreferencedentities comps 100 4 1 0 0 -byid
    # Handle error
    OP
    Hi @Adriano A. Koga.. I tried this API, it returns only the cross referenced entity type (in my case it shows only elems & sets).
    I would like to get the entity set name or id in reference with the node id.. Thanks in advance!!
    Altair Employee
    Accepted Answer
    i believe you're missing only retrieving the entities from the output selection (mark), with hm_getmark sets (mark number).
    INPUT> node ID
    OUTPUT> a list of entities related to the input, outputted into the desired mark (selection bin).
    >>to retrieve the output, use hm_getmark entity_type mark_number
    I've used a similar command below. My command has returned the cross-referenced entities into mark #1. Then I've used a few hm commands to retrieve their ids and names.
    OP
    INPUT> node ID
    Oh yes!! Thats right.. Works as expected.. Thank you!!
