🎉Community Raffle - Win $25
Join and Win
How do I fix the time step in nonlinear transient analysis?
User: "gslee"
New Altair Community Member
Updated by gslee
Hi,
My loadstep, TSTEP and NLPARM are as follows
image.png.3e55a30feff8b485292c4af8a4511069.pngimage.png.83e3dc3ffa6bee0c4d9bf3101ffccf17.pngimage.png.28c2c5a0e6832950c397bdb1f1b4d6db.png
In the result, the number of the time data is 432. (Its time step is not 0.0001)
I learned that when NLPARM and TSTEP are used together, DT on NLPARM overrides DT on TSTEP.
This result is caused by incremental load based approach in OptiStruct?
Thanks
1 - 5 of 51
    User: "Rahul Rajan_21763"
    Updated by Rahul Rajan_21763
    Please refer attached document for nonlinear transient analysis setup.
    User: "gslee"
    OP
    Updated by gslee
    I think there is no way to fix the time step in pdf file.
    In nonlinear transient analysis, I can control only initial time step size?
    Thanks.
    Time stepping scheme selected using TMTD parameter on TSTEP card.
    User: "gslee"
    OP
    Updated by gslee
    Thanks
    User: "Jaseguras"
    Updated by Jaseguras
    Hi Rahul,
    Why do you defined DT and TTERM equal (0.1) in the pdf example you shared? It's not supposed that TTERM should be set to the whole subcase time? As stated in the optistruct help.
    TTERM on NLPARM is to be input based on subcase time (not total time). For instance, in a multiple subcase setup, if subcase 3 starts at 2.0 and you want it to end at 3.0, then TTERM for subcase 3 should be set to 1.0 (since it is based on subcase time).
