Rigid Wall in Optistruct Explicit Analysis
User: "Prasad Srichandan Dalei"
Altair Community Member
Updated by Prasad Srichandan Dalei
Hi,
Could you please tell me how to reference RWALL in the Explicit subcase in Optistruct. I have defined RWALL but I am not getting any option to link that into the explicit subcase.
Thanks and Regards
Prasad Dalei
1 - 4 of 41
    OP
    I am running the explicit analysis but it seems that it is not taking the effect of RWALL in that drop simulation.
    User: "Guilherme_Brandao"
    Altair Employee
    Updated by Guilherme_Brandao
    Hello Prasad.
    Currently, OptiStruct does not have Rigid Wall for the native explicit solution. This feature was used for the OptiStruct/Radioss integration in the past. It should be supported in further releases.
    OP
    So I have to take another plate with very high Young's modulus value to replicate the rigid wall. Am I correct?
    Altair Employee
    You can use a conventional steel material and connect all nodes with RBE2 or RBODY. Then you apply the boundary condition to the main node. This way the part will behave as a rigid wall.
