🎉Community Raffle - Win $25
Join and Win
CBAR 800 has invalid orientation vector
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
CBAR 800 has invalid orientation vector ( zero length or parallel to the element axis). How to solve this error?
1 - 4 of 41
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    Try update orient of that cbar section by a node not colinear with cbar
    Altair Employee
    OP
    can you please shre more information about how to do it ,about this problem ?
    User: "tinh"
    Updated by tinh
    Hi Saber
    enter panel 1d>bar2>update
    select the elem
    set orientation as 'components'
    enter values vx vy vz somehow the vector is not parallel to the cbar elem
    Altair Employee
    OP
    @saber
    If the cross section axis is parallel to the tube axis, you will face this error,
    Make sure the axis are normal (by changing the orientation axis in 1D panel>>bars) and try again,
