CBAR 800 has invalid orientation vector ( zero length or parallel to the element axis). How to solve this error?
Hi
Try update orient of that cbar section by a node not colinear with cbar
can you please shre more information about how to do it ,about this problem ?
Hi Saber
enter panel 1d>bar2>update
select the elem
set orientation as 'components'
enter values vx vy vz somehow the vector is not parallel to the cbar elem
@saber
If the cross section axis is parallel to the tube axis, you will face this error,
Make sure the axis are normal (by changing the orientation axis in 1D panel>>bars) and try again,
