How to refine mesh in surface using refinement box option ?
Updated by Altair Forum User
I want to refine the mesh in certain portion of a surface and used refinement box option. But it refine only the interior elements and keep the surfece elements same. How to refine the surface using refinement box or is there any better option i can use ?
Image attached.
https://drive.google.com/file/d/0B2rIYPnVjYNEbGY5TkNHRUhtSFE/view?usp=sharing
1 - 7 of
71
Thanks. Now is it OK if i delete ' Element size control ' (in the component list) ?
yes, no problem. Once the meshing optimization is done, you can delete the temporary size component.
Altair Community Member
Updated by pkozlovsky
Hi, I ma trying to follow this procedure but I cannot force elements located on the solid boundary faces to remesh/refine also. Can you help me with that and take a look:
Hi,
Use Remesh option in Tetramesh optimization dialogue box to remesh the elements within the refinement box.
