🎉Community Raffle - Win $25
Join and Win
Progressive load with hyperworks
User: "Jesús Olvera"
Altair Community Member
Updated by Jesús Olvera
It happens that I have to do a test, with hyperworks, in which I subject a part to a progressive load, let's say as a tensile test, but the force does not change with respect to time but with displacement. The problem is that I haven't found any such procedure in the Altair manuals or tutorials ???? could you help me?
1 - 2 of 21
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    i don't have a right answer for you but i could suggest you to try adding a nonlinear spring (CBUSH) to your model, and assign a nonlinear force x displacement curve into your PBUSH property.
    This would be the only way I can think on having some control over the force according with the displacement, and not time.
    just an example of nonlinear spring attached.
    OP
    thank you very much, i will try it like this
