Altair RISE
Nominate Yourself Now!
PCOMPP Card image
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello, I am trying to assign PCOMPP card. But, there are some 2D elements. Is PCOMPP is compatible with 2D element. I am using optistruct as solver. after solving it is showing missing property error. Can you help me about this.
Thanks
1 - 10 of 101
    Altair Employee
    OP
    Hi @Bhushan D. Neve
    PCOMPP is only compatible with 2D elements. If you have 3D elements you need to use a different property like PSOLID.
    Altair Employee
    OP
    Thanks Prakash,
    One more question. I have define contact surfaces and tie contact between contact surfaces. If I change meshing of one component then contact surface has to be redefine or it will get automatically updated.
    Altair Employee
    OP
    Hi @Bhushan D. Neve
    If you did a remesh, the contact surface for the region will vanish. You need to create contact surfaces after remeshing.
    Altair Employee
    OP
    Okay thanks.
    User: "durukanbdilek"
    Altair Community Member
    Updated by durukanbdilek
    I also want to ask a question
    with this card image PCOMPP, how many ply we can model?
    for example, when I attempt to model a crfp laminate, which consist of 8 ply [0/90] I can only two ply
    how to realize in optistruct
    Altair Employee
    OP
    Hi,
    I am sorry, I did not get your point. could you explain this in detail, please?
    I want to model woven carbon fiber laminate whose stacking sequence is [04s/904s]
    • I create property PCOMPP
    • I create ply for 0o and 90o fiber orientation using PLY card image
    • I create a laminate adding this ply created previous step
    Problem, I have experinced, is I can use this ply once for both 0 and 90 ply I cannot use one more time and I have to create new ply
    Altair Employee
    OP
    Hi @durukanbdilek
    Since you have 8 plies in your stack, you need to create 8 different plies and refer all in laminate.
    it is absurd because I have only two ply
    I think this property must be changed.
    Altair Employee
    OP
    When i create ply, i can't put card image=ply. Why?
