1 - 10 of
101
- I create property PCOMPP
- I create ply for 0o and 90o fiber orientation using PLY card image
- I create a laminate adding this ply created previous step
If you did a remesh, the contact surface for the region will vanish. You need to create contact surfaces after remeshing.
I want to model woven carbon fiber laminate whose stacking sequence is [04s/904s]8
Problem, I have experinced, is I can use this ply once for both 0 and 90 ply I cannot use one more time and I have to create new ply
Since you have 8 plies in your stack, you need to create 8 different plies and refer all in laminate.
Hi @Bhushan D. Neve
PCOMPP is only compatible with 2D elements. If you have 3D elements you need to use a different property like PSOLID.
