Simcode Variable frequency PWM
1 - 2 of
21
Hello.
I do not want to create a separate thread for a related question, so I ask in this thread.
I need to create two Variable Frequency PWM blocks with 180 phase shift between each other. They work fine when the input of variable frequncy blocks is 1. But, once it changes, the 180 degree phase shift (on PWM2) becomes glitched in the simulation and changes to some other value.
P.S. Once uploaded to the DSP it is actually working well.
Thanks in advance!
Please make sure the name in the "1-ph PWM" block is the same as in the "Variable Frequency PWM" block.
