🎉Community Raffle - Win $25
Join and Win
Import problem
User: "Nayara Lacerda"
Altair Community Member
Updated by Nayara Lacerda
Can anybody help me with this? I think it might be a simple problem.
Sometimes when I import a geometry on OptiStruct, which is an assembly, the software does not recognize one of the parts as a solid. So, it is not possible to mesh it or to do anything else. The picture below shows an example of this, with the topology view.
1 - 3 of 31
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    You can create your solid from closed surfaces.
    OP
    Thank you.
    But even so, I get the error "Volume Analysis: no solid selected. (no error highlighted) Meshing failed". And even when I delete the component and use the mesh created (^temp_2d_for_tetra) I can't run the analysis because the software does not recognize the elements. And because of that I can not create a contact surface either. Therefore, I get a lot of errors when running the analysis. Do you know what might be causing this problem in the when importing the geometry?
    Thanks a lot.
    OP
    Thank you.
    Thanks a lot.
    In case anyone has the same problem, I solved it by changing the file format. It was in IGS format and I changed to STEP and it worked.
