Hi,
I'm trying to run a simulation but there are many of my elements (3D solid and 3D Shell) where I have the Error ID 79 (** ERROR : DUPLICATE ID). What can I do to suppress this error?
(I already check if I had more than one mesh, but no)
thanks
Hi Ram,
These are based on the applications. If user wants to create the component rigid,it should be done using Rbody. Whereas for connections spring elements can be used.
Dear George,
I have cleared the Rbody error by using spring elements with high stiffness, but unable to clear the admas error.
Thanks
RAM
Please recheck the /ADMAS defined in the model. You need to create a nodal group (/GRNOD) and then assign this to the /ADMAS card.
/ADMAS/0/1235199 admass_ADMAS1060 # MASS grnod_ID .11 30823 /GRNOD/NODE/30823
I have cleared this admas error.but getting the following error
ABNORMAL END | | Segmentation Violation | | TRACE BACK : | +=============================================================+ RIGID BODY ELEMENT DEACTIVATION +=============================================================+
ERROR ID : 760 ** ERROR TRAPPED
This seems like a modelling error. Please share the model files and out files.
File shared to your dropbox
What is the modeling error in that model?
Please let me know the corrections to be made.
I just got your model. Will check and update you.
Thanks for your update
Tanks
Please update your HyperWorks suite to the latest version and try running. I got only the error regarding the interface defined.
HyperWorks 2017 suite is available at https://connect.altair.com/. Please update and try running.
.out file is attached for your reference.
What is the error in interface definition??
Please check the interface defined in the model. You can review the same error in the out file attached in the above reply.
I have deleted and recreated the interfaces but still the error occurs
** ERROR TRAPPED : REPORT TO LISTING FILE ERROR ID : 760
Did you try the same with latest version, HyperWorks 14 or HyperWorks 2017?
Please share the out file.
Shared the out file in your dropbox
I am using version 13 ....
Please update your HyperWorks suite to the latest version and run the analysis. Please try with HyperWorks 14 or HyperWorks 2017 version.
