Altair RISE
Nominate Yourself Now!
Error ID 79 : ** ERROR : DUPLICATE ID
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I'm trying to run a simulation but there are many of my elements (3D solid and 3D Shell) where I have the Error ID 79 (** ERROR : DUPLICATE ID). What can I do to suppress this error?
(I already check if I had more than one mesh, but no)
thanks
31 - 46 of 462
    Altair Employee
    OP
    Hi Ram,
    These are based on the applications. If user wants to create the component rigid,it should be done using Rbody. Whereas for connections spring elements can be used.
    User: "RAMGANESH"
    Altair Community Member
    Updated by RAMGANESH
    Dear George,
    I have cleared the Rbody error by using spring elements with high stiffness, but unable to clear the admas error.
    Thanks
    RAM
    Altair Employee
    OP
    Hi Ram,
    Please recheck the /ADMAS defined in the model. You need to create a nodal group (/GRNOD) and then assign this to the /ADMAS card.
    /ADMAS/0/1235199
    admass_ADMAS1060
    #               MASS  grnod_ID
                     .11     30823
    /GRNOD/NODE/30823
    User: "RAMGANESH"
    Dear George,
    I have cleared this admas error.but getting the following error
     ABNORMAL END                                            |
     |          Segmentation Violation                             |
     |     TRACE BACK :                                            |
           RIGID BODY ELEMENT DEACTIVATION
    ERROR ID :          760
    ** ERROR TRAPPED
    Thanks
    RAM
    Altair Employee
    OP
    Hi Ram,
    This seems like a modelling error. Please share the model files and out files.
    User: "RAMGANESH"
    Dear George,
    File shared to your dropbox
    Thanks
    RAM
    User: "RAMGANESH"
    Dear George,
    What is the modeling error in that model?
    Please let me know the corrections to be made.
    Thanks
    RAM
    Altair Employee
    OP
    Hi Ram,
    I just got your model. Will check and update you.
    User: "RAMGANESH"
    Dear George,
    Thanks for your update
    Tanks
    RAM
    Altair Employee
    OP
    Hi Ram,
    Please update your HyperWorks suite to the latest version and try running. I got only the error regarding the interface defined.
    HyperWorks 2017 suite is available at https://connect.altair.com/. Please update and try running.
    .out file is attached for your reference.
    User: "RAMGANESH"
    Dear George,
    What is the error in interface definition??
    Thanks
    RAM
    Altair Employee
    OP
    Hi Ram,
    Please check the interface defined in the model. You can review the same error in the out file attached in the above reply.
    User: "RAMGANESH"
    Dear George,
    I have deleted and recreated the interfaces but still the error occurs
     ** ERROR TRAPPED : REPORT TO LISTING FILE
    ERROR ID :          760
    Thanks
    RAM
    Altair Employee
    OP
    Hi Ram,
    Did you try the same with latest version, HyperWorks 14 or HyperWorks 2017?
    Please share the out file.
    User: "RAMGANESH"
    Dear George,
    Shared the out file in your dropbox
    I am using version 13 ....
    Thanks
    RAM
    Altair Employee
    OP
    Hi Ram,
    Please update your HyperWorks suite to the latest version and run the analysis. Please try with HyperWorks 14 or HyperWorks 2017 version.
31 - 46 of 462
