🎉Community Raffle - Win $25
Join and Win
Licensing Problem
TEJAS C CUser: "TEJAS C C"
Altair Community Member
Updated by TEJAS C C
I Have been trying for since a week to activate the software and get going but it hasnt been possible, I have followed all the troubleshooting steps and licensing steps. Finally it has come down to this
Please help me i am not able to understand what is the problem.
1 - 3 of 31
    Few observations:
    I assume from your screenshots, that you have a 'standalone' license?
    I can see you have path set in user set in both user and system, I set only in system, and, have the full path, including license name: e.g:
    Your license file is named "altair_lic (2).dat" please try renaming it to "altair_lic.dat"
    OP
    Yep
    did as you told. but still not able to activate
    Yep
    your screenshots show you haven't done what I said!
    your local variable is just the path (it doesn't include the file)
    and you still have a system variable set too
    also, I note you have installed in a folder indicating this may be edu version? in that case you wouldn't have a standalone license normally, the activation would be using HHWU, are you sure standalone is what you have?
    If this is an edu package, you should really ask in the academic forum: Academic Forum
