Can anyone help me with Rock Cutting Simalation ?
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
I was using some material properties. when cutting tool is going to cut the rock, the tool is not cutting and tool position is changing and moving on it.
how to solve this simulation
Welcome!
Answers
  • Dhanasharee Jadhav_21915
    Dhanasharee Jadhav_21915 New Altair Community Member
    edited September 2020
    Hi,
    You can Perform this Analysis in Radioss or In Motion Solve .It depends on what is the objective of cutting. If it is to see the forces on the tool, heat generation etc then RADIOSS. Please tell me your Objective of Analysis.
    Regards,
    Dhanasharee Jadhav
    Hi,
    First you  need to fix the Objective and have data for Rock and Tool.
    Regards,
    Dhanasharee Jadhav
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    depending on what you want to do, you could use SPH to represent your rock and a rigid body for your tool.
  • Ovunc
    Ovunc Altair Community Member
    Hi,
    Firstly, thank you for information.
    So how is the ideal number of particle determined in models with SPH? /profile/97129-adriano-a-koga/?do=hovercard' data-mentionid='97129' href='<___base_url___>/profile/97129-adriano-a-koga/' rel=''>@Adriano A. Koga
    Thank you.
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited October 2020
    just like regular FEA models, i would say this depends on a few factors, and a convergence analysis would be a nice approach. I mean, start with a small particle numbers, then run a new model with more particles, and so on, and then compare your results. Of course it depends on what you're trying to compute.
    Just as an example, there is an example model in this topic, create by @Rodrigo Merigo.
    https://community.altair.com/community?id=community_question&sys_id=5e76c43a1b2bd0908017dc61ec4bcb6e
  • Ovunc
    edited October 2020
    Thanks for the previous information Mr. Adriano. @Adriano A. Koga  @Adriano Koga
    I am planning to prepare a model that includes SPH. However, I am new to this. I could not find much information.
    Can we say that as the number of particles increases, the results get closer to a certain value? And after a certain number of particles, increasing the  particle number wont effect the simulation results? (which is the case for mesh convergence in FEM analyses)
    Are there any tutorials, academic paper etc. that you know about the subject and that I can use as a reference?
    Thank you.
    Regards,
  • Adriano Koga_20259
    Adriano Koga_20259 New Altair Community Member
    edited October 2020
    Hi @Ovunc2
    Attached is a model created by Rodrigo Merigo that performs a machining process using SPH.
    For creating your SPH you need to go to Mesh >>Create >>SPH
    take a look at Radioss documentation for more details on SPH and the example in the documentation, attached.
  • Ovunc
    edited October 2020
    Hi,
    Thank you very much Mr. Adriano @Adriano Koga .
    Regards,
Welcome!
Welcome!
