How to export an optimized shape from Inspire to Inspire Studio in order to create a polynurbs
I followed a class Inspire Studio PolyNurbs and Optimization which took place on May 16, 2023 at 9:30 AM-12:30 PM.
I would like to practice but I don't know how to export an optimized shape from Inspire to Inspire Studio as seen during the class. How do you do to be as in below ?
If I import a STL file, it seems to be heavy to manipulate in order to construct a smoothed polynurbs.
1 - 1 of
11
Hi Emmanuel,
Usually we go via STL and the results of optimizations are normally kind of rough so the density of the polygonal geometry should not give any issues.
If it does, please send me the optimization results as a support request from Altair One.
I will check that and will let you know.
Regards,
Antonio
