Altair RISE
Nominate Yourself Now!
buckling analysis of plate
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hello sir,
i created a plate in optistruct, meshed it with only quads, assigned material and property. created load collectors spc,load and buckling with buckling card image as eigrl and remaining with no card image. created forces and constraints and also load steps with linear static analysis spc and load, for buckling analysis method struct,spc and staticsubcase. and then carried analysis, am getting error 14, please help, forgive me if its a silly doubt
thankyou
1 - 4 of 41
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hello
    Please send us your model for faster debug
    At least, post the error description, not error code
    Altair Employee
    OP
    hello sir,
    thanks for quick reply. here i attach error description file, am new to hyperworks, thanks for help.
    User: "tinh"
    Updated by tinh
    Hi Kavya
    It's very clear that you did not assign property to elements
    On Model Browser, right click to the components, select 'Assign', pick the property, then click 'apply'
    (or assign prop by Entity Editor (HM13)
    Also you should check again the property already referred to material or not
    click on property, look at 'Material' row in Entity Editor
    If you are new user, you can use Basic FEA User Profile, it's more friendly
    Altair Employee
    OP
    thank you sir
