Shape Optimisation error
Updated by Altair Forum User
I am getting this error in performing shape optimisation. Cai I know why I am getting this?
** OptiStruct 12.0.212 **
** Design and Optimization Software **
** from Altair Engineering, Inc. **
** Windows 7 Workstation SP1 (Build 7601) MEN-PC5209 **
** 8 CPU: Intel® Xeon® CPU E5-1620 0 @ 3.60GHz **
** CPU speed 3600 MHz **
** 9650 MB RAM, 32617 MB swap **
** Build tag: 0688910_5533120_Ce64RBW8UH12M:83688-000 4000000004000 **
** COPYRIGHT © 1996-2013 Altair Engineering, Inc. **
** All Rights Reserved. Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc. **
** Decompilation or disassembly of this software strictly prohibited. **
*** OptiStruct defaults set from:
install config file: C:\Program Files\Altair\12.0\/hwsolvers/optistruct.cfg.
NOTE # 9199
MSGLMT=STRICT is active, all messages will be printed.
You can suppress some less important warning messages by use of
MSGLMT=BRIEF or UNREF (in config file or in the input data).
1 PARAM(s) were set:
CHECKEL ,NO
*** See next message about line 2109773 from file:
F:/New optimisatin/1/run1.fem
'CTETRA 762986 0 246586 9426 9422 9423'
This line was interpreted as:
2109773:CTETRA, 762986, 0, 246586, 9426, 9422, 9423
*** ERROR # 1000 *** in the input data:
Incorrect data in field # 3.
Expected INT > 0, found INTEGER (0).
*** See next message about line 2109774 from file:
'CTETRA 762985 0 265163 181999 182000 132385'
2109774:CTETRA, 762985, 0, 265163, 181999, 182000, 132385
*** See next message about line 2109775 from file:
'CTETRA 762984 0 216315 252454 206422 212897'
2109775:CTETRA, 762984, 0, 216315, 252454, 206422, 212897
*** See next message about line 2109776 from file:
'CTETRA 762983 0 170857 207340 199941 243653'
2109776:CTETRA, 762983, 0, 170857, 207340, 199941, 243653
*** See next message about line 2109777 from file:
'CTETRA 762982 0 142391 244486 149158 142392'
2109777:CTETRA, 762982, 0, 142391, 244486, 149158, 142392
*** See next message about line 2109778 from file:
'CTETRA 762981 0 134198 246452 222030 220510'
2109778:CTETRA, 762981, 0, 134198, 246452, 222030, 220510
*** See next message about line 2109779 from file:
'CTETRA 762980 0 507899 547696 490468 538040'
2109779:CTETRA, 762980, 0, 507899, 547696, 490468, 538040
*** See next message about line 2109780 from file:
'CTETRA 762979 0 252555 190641 155900 278723'
2109780:CTETRA, 762979, 0, 252555, 190641, 155900, 278723
*** See next message about line 2109781 from file:
'CTETRA 762978 0 204486 298774 210444 198028'
2109781:CTETRA, 762978, 0, 204486, 298774, 210444, 198028
*** See next message about line 2109782 from file:
'CTETRA 762977 0 331341 263043 309313 267951'
2109782:CTETRA, 762977, 0, 331341, 263043, 309313, 267951
*** More of ERROR messages # 1000 were suppressed...
*** See next message about line 2119772 from file:
'CTETRA 752987 0 235663 114018 114015 113997'
Too many error messages. Aborting run.
Current limit is 10000. Use 'MSGLMT' control card to change this value.
Following warning messages appeared too many times
and were suppressed:
1000
Total of 9989 repeat error message(s) were suppressed.
To see more messages use 'MSGLMT' control card in the data or config file.
1 - 4 of
41
Swapnil,
Make sure you have assigned the compatible property to the elements. In your case PSOLID should be assigned to CTETRA elements.
Swapnil,
dear bro how and where we can assign the PSOLID to CTETRA elements?
Hi Waqas,
Organize solid elements into a component and assign PSOLID property to the same.
This seems to be a formating problem? .. but it interprets it correctly - so it seems to me..
thats the mistake. There is no property assigned to some elements (PID = 0).
if you have elements that are 'unused' i think you need to delete them. all elements need a proeprty (linked to a material data, ...) assigned.
